i'm not sur.. the gears are 2, 3 and D4.. 3 speed or 4?? but the gear box was changed.. it used to be manual.. maybe that's why?
can you show me a diagram of how to do the grounding?.. what wires to use and where can i get them?
very easy onli.. just drive slow..whnever auto change gear, u will feel the pull or the engine sound will change.. if just change 2 times tht means 3speed onli and if change 3 times it will be 4speed lor coz whenever u launching time, it will be at 1st gear..hehe...
grounding wise will be very easy...
1st of all, did u change the battery connector to big one? or still using the ori one?
if u use the ori, u need to change it.
After tht u measure the cable (u can use those accessories shop use to put the amp current cable) that how long and where u wanna to put it.
The cable must be measure from
- -ve (battery earth) to car body - 1 cable.
- -ve to engine body (anywhere that got screw) - 1 cable
- -ve to starter body - 1 cable
- -ve to alternator body - 1 cable
air cond compressor body also can if u really want it..hehe...
after measure all the cable....
use a connector just like this (-O) to make it more nicer...
Screw all into the body and battery earth then...close case liao lor...
hehehe...1 hour job...
