Power Window Problem
riduanteo
Sifu want to ask a question here again before i start my ques i want to thanx to sifu because willing to answer my past question. ok the stories is my car window switch cant work properly so i panas and keep pressing the button until its come out alot of smoke after that both of my power window cant work anymore, then my central lock cant work but my alarm is working just wondering what happen actually bring it to check all my fuse is ok but so sad the wiring man is back home dy coz its kinda late yesterday when i bring my car to workshop any idea here? any recomender place to fix this probs around usj and subang area?
What car?
Should be a burnt fuse... unless you're SERIOUSLY jinxed & you burnt the wiring :frown:
Im driving a saga LMST if burnt the wiring then izzit expensive to fix ? i think i burned the wiring so how to solve this ah ?
Hmm, all I can say for burnt wiring is get a good wireman. It's gonna be a long, unnerving process :frown:
Sound like motor overload coz smooth out.
Both power window cannot use is because main switch from drive side was burn.
Few itmes u need to check,
1st, fuse for power window ( alarm should share same current with power window )
2nd, power window motor.
3. Power window switch.
Just send ur car to workshop, they know how to solve ur problem.
btw, this is very minor issue.
Hope can help.
