yes agree with f4r0k..what is your fren's boost? it might be boost cut not rev cut..just assumption but it's worth to check..if the boost more than 0.9bar at the said 6500rpm, maybe it's your boost over than what your map sensor and ecu can read..others maybe your fuel too lean, maybe too rich..but the error code saying ignition as one of the problem, maybe you could check that too..swap your dli unit with another fren with same unit and see how's the result..pls sifus correct me if i am wrong.
I just borrow my friend boost meter today, found out when normal operation it was 0.9bar. But dunno why once it hit 5800rpm and above, the boost sudden increase. Therefore same as you said it is boost cut not rev cut.
Anyone know why the boost can sudden increase? Are it because of waste-gate or because of cam setting issue?
