- Joined
- Jan 17, 2006
- Messages
- 11
- Points
- 1,501
excuse me..... i'm new here. i just want 2 ask a few questions. do i have 2 change handbrake cable if i'm using putra rear disc brake? i'm using iswara n 8 hole rims, so it's just like "plug n play la"?
abflug34 said:darrahitam and vestax ..
cheers bro.. i wanna ask about ur disc brake solution for saga iswara..
now i have a set of mitsubishi FTO rear disc brake complete with cable arm and everything.
the disc have been driil from 5lugs to 4lugs PCD114.3
i've read ur posting but dont understand much of it coz i dont really familiar with braking system.
and now my question is..
can it fit my iswara?
any guide?
qib_akip said:ello bro!!! how much selling the rear disc break? with installation? gimme ur best price laaa.... if possible, i need sum 1 to look at my car. cos i've just fit a vr4 into my saga, but its quite hard for me to say. my handling totally lost( jalan macam ketam) easy to say, still under construction laaa, setting xngam laa, etc... anybudy can help? hit me back pls.... tq....
http://i15.photobucket.com/album/a385/keramatman_2005/tierodkon.jpgvestax said:the problem will always be with the knuckle , alot of people who use the vr4 knuckle are not aware that the tie end rod is not compatible with the knuckle , yes it will fit but there will be some problems with the camber adjustments later on .
so best way is to use back the standard knuckle & bearing and match it with the brake set .
about the hose , im not sure if perdana is the same with wira , if its the same then it should fit , if not have to change to the wira 1.6 hose .
