Hai all the sifu out there if you ahve any exp for this pls help me!!!
cause i am having huge problem with it
okok cut the story short, my conversion 4AGE 20V into RWD. firrst i bought the whole half cut than it goes to a mech shop than the mech strip down every thing form the halfcut without taking pics, than later the mech run away dont know for what reason. than i have to change to another shop this mech very good in transplant engine. but i dont think he is good in vacuum line.
Engine in, full set wiring in, without aircond control unit, ABS, dash board, air-cond blower.Others i think all in
Problem
Engine cant idil properly, BT slow is tune by ecu and by ISC right but why mine cant??? by the way some vacuum hose are mess up, some are not connected. if any one know this or shop who know this pls let me know or have pics pls let me see.currently the mech install a bracket to stop the throttle from going back to the end to make the engine idle if not the engine will die, cant idle at all. i think this is wrong.
when aircond is turn on the engine will not idil higer, the question is, does this follow the vacuum or the digital system????
Note: Auto engine mix with RWD gear box so not torque converter
Any one out there can help me i dam headach!!!!!!!!
Problem
