- Joined
- Jul 8, 2006
- Messages
- 55
- Points
- 1,506
DoSe Friction Modifier
http://img241.imageshack.us/img241/5139/friction01dq3.jpg
DoSe Friction Modifier is an additional additive to car engine oil for smoothen the running. These tiny designed balls will melt and mix together with the engine oil to produce better frictionless surface between static and moving engine part. It makes a film between surfaces of parts moving against each other so as to minimize direct contact between them decreasing friction. It also help engine oil to carry away the heat caused by the moving particle inside the engine. As a result of this, cars engine will run smoother & produce less noise.
Benefits Using DoSe Friction Modifier;
-Less Friction
-Reduce Heat
-Reduce Engine Noise
-Smooth Driving
Its also can be used with car gearbox oil. It will make gear shift smoother.
How to use it?
Open the cars engine oil cap. Pour DoSe Friction Modifider. It will melt itself n mix with the engine oil while running.
http://img151.imageshack.us/img151/8844/friction40603pe7.jpg
Recommended to use it with new oil. If u just service your car few months ago. Just add it on.
With DoSe Friction Modifier. You can enjoy a smooth drive!!
TEST IT & FEEL IT YOURSELF!
PRICE: RM 19.90
RM4 charged for deliver thru postage.
Contact Method: Post reply/ pm/ call 0164576745 or 0122270809
Delivery Thru Postage To All Over Malaysia.
-Less Friction
-Reduce Heat
-Smooth Driving
How to use it?
PRICE: RM 19.90
