Need some feedbacks on this issue I'm been monitoring:
1) Engine oil level seem to drop.
Checked the dipstick, realised it drops 1-2mm after 5 days of driving, boosting once a while.
Have been topping up (1/3 of a litre at once) every 2 weeks.
2) Water level in reservoir (for radiator) drops after driving for 5 days.
Been topping up every week.
Checked the Radiator, level is always full.
Extra related info + other items I've did in the last 6 months to try to fix this.
1) Compression test - perfect - all 4 pistons perfectly same reading
2) Complete Top Overhaul including metal head gasket. (including rocker cover seals etc..)
3) Repair Kit + Change shaft for the turbine.
4) Flushed Radiator.
There are no visible leaks anywhere looking at the engine bay. Always checking on the common places as I'm paranoid to oil leaks. Always clean around the engine all the time, spraying motul parts cleaner here and there, wiping around just to monitor if there are leaks at specific places etc...
Other than that, no performance drop issues or mechanical issues anywhere. It runs very smoothly anytime of the day, no temperature rise etc...
Dear Sifu's and Vin Diesels, I need some feedbacks and your experience.
What else could be done or be checked? Thank you in advance.
Bump: I knew it... not many ppl can answer this... very isolated case... :rolleyes:
