B16Alaric said:Thank you to everyone for the feedback.
I brought this matter up with some friends of mine who are really into the mod scene and I have also screened through many many websites and forum.
The bottom line I hear is.... change to manual !!!]
Hahaha!!! I have considered every solution to increase my hp (crv-tec, turbo, performance cam, etc) but i'm told that it's not worth it cause most of the power gets trapped by the slush box !!!
My question is... Does a manual gearbox really make that big a difference?
EG8 said:Definitely yes.Autobox is crap, if im not mistaken b16a autobox can only held max 155ps, more than that it shall shorten your gearbox lifeshelf, if you wanna go for performance, go for manual.
p/s: i myself driving an autobox
ARTA said:Wat Bro EG8 mean is the auto gb can withstand up to 155ps, not produce hp...
Cheers :)
ARTA said:Bro B16Alaric: Ecu, cam ,valve springs, and gb difference....and all tat makes a big difference
Bro c1kai: The distributor damage might be caused from electrical problem. Some distributor suffers burnt bearing resulting from high rev. (too old for some recond parts..cant stand the rev)
Like the case i experienced before, i revved my engine till 8K while blasting my normal audio setup with aircond headlamps and foglights on (i had 4 fog lights...last time my car quite rice...hahaha) With all the electrical component as a burden while revving , the distributor cant take it.. The inner part where it always suffers damage of a Big V's distributor can be replaced while small V's cant. Small V's distributor, u haf to DIY or ask your reliable mech to repair it for u...as for mine...i replaced the whole distributor.
Arta, does it mean that B16A (A) has diff ecu, cam ,valve springs compared to B16A (M)? Do u think it is also the same for other cars?
aboo said:ARTA said:Bro B16Alaric: Ecu, cam ,valve springs, and gb difference....and all tat makes a big difference
Yes, B16A auto have different ecu, number of valve springs (I'm comparing the small V's ) and especially the cam. I've experience these two cams before and there's big difference. What do u mean by other cars? as in mitsubishi? or other honda car? For other honda car, i wasnt too sure..
c1kai said:sorry to interrupt in between the conv. but do any-1 here ever encountered distributor problem koz mine went kaput 2 times in a row... btw my ride is b16a with auto tranny.. any idea to recond the distributor as the new taiwan made had cost me about RM350...![]()
B16Alaric said:Hello to all the Honda Motorheads, i'm a newbie with a problem...
I am running an automatic B16A in my 1997 Civic. I've tried all the common mods... an open pod filter, heat shield, custom exhaust and a Apexi V-AFC2. I've even put in a ZEX Wet Nitrous Kit... but i still can't enough power to satistfy me.
Came across a 2nd hand turbo kit just right for my car in a shop in Sunway. Its a td05 turbo with a HKS blowoff valve, Evo5 intercooler, and so on so on. I'll also need to get a Greddy E-manage system as well apparently. The shop offered to do the whole set up for about 10k including tuning, redoing my exhaust, piping and installation. It's a light pressure turbo if i'm not mistaken.
Is this a good deal? Is this even a good idea to put in the turbo? I hope someone could give me some advice. Thanks in advance guys !!!
