what is the BEST BOOST CONTROLLER ?
one of my customer break his turbo shaft bcoz of the profec b type2 selenoid fail...evo9 tu bro...:bawling:
break turbo at the same time will damage abit ur engine:rofl:
Bump: if u wanna hi boost like 2bar ,use wrong boost controller, over boost 0.1bar,olso can blow ur engine man~stable is very important:smokin:
actually, do anyone know what's the benefit of dual solenoid versus a single one?
dual solenoid is more accurate, i think..correct me if i'm wrong..
hey guys try out the FGB manually boost control from Australia...
very good product for me...
reliable too worth every single penny i spent on this item
MBC is definitely the best, set and forget and very reliable.
Electronic systems are difficult to tune unless you find someone familiar with the gain settings and they are quite unreliable..
Hi,anyone mind to share where can i get this GFB Manual Boost Controller?
Thanks
You can get other similar ones here like Hallman, Works, Turbosmart or some other no brand ones range from RM100-200+. Not sure if anyone selling GFB here, Hallman is similar - also Aussie brand.
Im using MBC too :thefinger: Spent a lil on MBC, spent alot on engine mod :thefinger:
i saw n1 selling ARK boost controller....seen like so nice !!
anyone install that ?? that size same as apexi turbo timer..
Thanks Ehdrian...but which Eneos? Is it reliable and stable on the boost control? If boost up to 1.7bar any problem?
1U punya eneos..maybe my turbo's actuator got prob or smth wrong cos i set my boost at 1bar using the GFB mbc, when i floor the pedal, the boost will shoot to 1.2bar, now i got scared and set at 0.8bar but on full throttle, the boost spike till 1.1bar...maybe u can ask around those who's using the GFB mbc and see wat they say cos maybe my turbo got prob..
Thanks
KSP they got~
---------- Post added at 07:39 PM ---------- 6 hour anti-bump limit - Previous post was at 07:33 PM ----------
if want stable please use turbo smart boost controller,the go fast bit boost controller also okay,last time i got use GFB boost controller will spike but just 0.1 like this only~no 0.2 or 03 lol
---------- Post added at 07:50 PM ---------- 6 hour anti-bump limit - Previous post was at 07:39 PM ----------
DIY Dual Solenoid Boost Controller + trigger switch.... :driver:
murah2 saja....
Most MBC will spike 0.1 it's normal.
That's how you tune it anyway, set the value you want to spike to and the constant value, normally like spike to 1.3 settle at 1.2.
