Errr... I disagreed tht when u aiming for 400-500hp, u hv to dismantled the MIVEC system for tht... Hahaha... I'm sure some of u must hv heard abt the HKS V Cams system!!! This V Cams system (both intake and exhuast cams) r specially design for Evos tht r not equiped with the MIVEC system in order for them to get the similar low end torque power as did in MIVEC turbo Evos, even if they r aiming for high hp for their cars.... HKS even develop this system for other cars too, eg. GTRs, Z33, Scooby and many others... This cams hv got higher lifts and degrees for various set up....
And of cos, HKS do hv records to prove (dyno charts on various type of cars tht r using the V Cams system to gain higher hp but oso maintaining the low end pull force)... There were comparison charts for cars going with n without the V Cams... And d diff r obvious!!!
In d market now, there r oredi lotsa after mkt parts for Evo X!!! Strokers, turbos, ECUs, suspensions, bodykits, rims n etc... U name it, they hv it... What i love most from the Evo X is the 2 Recaro seats!!! Hahaha... They r NICE n comfy!!!
Andreas,
Sorry tht i didnt make it to the last TT!!! Hahaha... As Ben hv said, I'm an uncle now!!! Hahaha... Hardly 'able' to hangout late!!! But I'm sure we will b able to meet up soon!!! Cheerz!!! If u do need any info as in E9, i'll try my best to answer u ya~
Oh ya, how high hp u r aiming at 'If' u r going for the Evo X?! Cos 5 speeder manual will hv better potential than the SST tranny!!! If I'm not wrong, the SST tranny will 'onli' b able to stand up to ard 400hp... It will b an expensive item to repair or replace, if it really gives problems or give way due to higher hp from yr set up!!! But i know tht HKS is gonna come out with some sort of after mkt tuning package for the SST Evo X...
But i dun think it will b a big problem, as the same case oso apply to Nissan latest KING of the road - GTR35... Ppl jus add a bigger old pan, a gearbox oil cooler, higher quality gear oil (all WILLALL racing products) and then most importantly they 're-tune' d gearbox system too - especially d Launch control... I think sooner or later, they will hv the similar products for the Evo X SST box too... Will keep u n everyone on update on this...
James,
Ooi... No Pamela Anderson la... Onli Tavia Yeung nia~~~ LOLzzzzzzzzzzzzz....
James,
thx for u post lah. Some comments from my side.
As I'm used to have VTEC in my last two cars (Honda CRX and S2000), the obvious is that there is only soo much you can do to cams when you change for example the size of the intake and outtake ports size in a good head job, you optimize the manifold and intake on the flow bench, the amount of fuel you're providing (by more fuel pressure or better bigger injectors), the ignition setting most of all. This is going to influence your optimal cams setting, as with a different amount of air/fuel mixture you put in and a different timing on ignition you need to alter your cams too when it comes to when they should open and close and how much overlap you need.
It all has to do with the perfect burning of the fuel in the small fraction of time that two cycles give you. Depending on the quality of the fuel it burns with a specific speed per millisecond, you don't want to see detonation happen or pre-ignition, you don't want to let unburned fuel exit through outtake into your cat killing it (gives nice flames though), right?
So to let's say 80% you're right, the cams will provide more hp along you tune, but for the last 20% of power your might need to look at your cams too, changing their profile along with your extreme tuning measures, otherwise you'll loose potential there. I have a good friend who calculated cam profiles when he was working for a car manufacture in Germany.
On the other hand I'll probably be happy with just adding 100 hp or so to my stock hp.
When it comes to wear and tear on your SST, this once again is depending on your tune. The thing that is going to kill you SST is the high torque, higher than the components can last, right? This is why some car manufactures are limiting their torque like Brabus or the Bugatti Veyron.
You can achieve this in your tune by limiting boost in lower gears (at least it's possible with a good standalone EMS) and only allowing full boost for example in 5th and 6th gear (when you go for max speed and power).
Just my two cents, but very interesting discussion I see,
Andreas
---------- Post added at 01:01 AM ---------- Previous post was at 12:53 AM ----------
dear andreas,
no matter what evo u decided to buy, nice to know u and have u in our club....waiting for your new ride and we go cruising uphill...heard you are a pretty daring driver....by the way, nice to meet u at tt the other nite and couldnt have chance to talk to u coz u r so occupied with our taikors.........aka big bro ben, bro leslie and bro mizu......
Looking forward to discuss next time, we have to leave some topics open, right? It was a bit difficult as I had that boom-boom box screaming into my ears while I was trying to listen to you guys, not easy for an old man with not so good hearing (too much loud disco music when I was young, haha).
Hope we'll have some fun driving too when I do have my ride, so far I only saw you guys sitting, talking, drinking and eating, some showing up even without their ride. Would be completely impossible to have such a TT when it comes down to S2000. We would try to kill our tyres any time, haha.
Andreas
