Just dynoed today...hope this is healthy one...
Engine:
BLT with 6sp
NGK Plug cables
K&N Open Pod Filter
TRD Metal Gasket
Apexi N1 piping with RSR Invidia S-Flow Muffler
The rest stock.
Is it normal that the max torque in RPM range 5-5.5k???
Cheers...
he asking y bt standard from dyno not 165hp as factory mention. hehe
wow..your stock engine produce 160hp...impressive![]()
Hi all master sifu out there need you sifu leading. what is the max & min tolerance compression between 4 cylinder for the Bt20v?
I just check mine, for the 1st & 2nd piston compression it’s about 190++psi nearly 200psi btw cylinder 3rd and 4th its about 200++psi nearly 210psi. There its 10psi lesser for 1st & 2nd cylinder compare to 3rd & 4th cylinder its that ok?
Originally Posted by TRD.AE92
Factory is mention Engine HP not Wheel HP man!
Hi all sifu
i though the stock BT hp is ~163hp? why from the dyno result it < 160hp ...
From wikipedia:
Fifth Generation "Black-Top"
The fifth-generation 4A-GE engine produced from 1995 to 1998 is the final version of the 4A-GE engine and has black cam covers. This engine is fondly known as the "black top", and yet again features an even higher compression ratio (11:1), the air flow sensor is replaced with a MAP sensor, the diameter of the four individual throttle bodies was increased from 42 mm to 45 mm, the exhaust port diameter was increased, the intake cam lift was increased from 7.9 mm to 8.2 mm and the intake ports were significantly improved in shape, contour and also the width at opening at the head was increased. This revision increased the power to 165 PS (121 kW; 163 hp) at 7800 rpm with 162 N·m (119 ft·lbf) at 5200 rpm of torque.
finally my BT conversion is done.
when to dyno & tune at Nortern Garage.
setup:
1) stock BT Engine
2) Using Ron95 petrol
3) stock plug cable
4) Open port Apexi filter
5) Sars fuel regulator
6) Custom piping 2.2" with lousy S-flow muffler
7) iridium plug
8) Idemitsu 10w/40 already run 2000 km since conversion
9) Piggyback Unichip-Q
The dyno graph based on 4th Gear
only able to get ~158hp (Engine HP) and 168Nm Torque.
any one can advice/comment did my stock engine look healthy ?
you bring it up hat mean alive he he
synchron's 4age turbo 325hp @ wheel!! sapu everyone during the dyno day
look at how evil his face is... hahaha
http://www.autojunctions.com/images/stories/2010/event/dynoday/ben/IMG_1288.jpg
