- Joined
- Oct 18, 2008
- Messages
- 226
- Points
- 1,518
hi..
it happened this morning. try about few times to start the car, heard the 'click' sound and the last twist succeed but took about 3 seconds before the starter kick in. after that, the starter wont turn off even i turn off the engine and pull out the key.
the starter keep running even without key inserted. less than 1 minute, my battery gone.
call a friend, pick me up..go to work.
just now, came back from work. removed the starter relay (thought the relay was the culprit) and jumped with my friend's car. the moment we connected the jumper, the starter run. the jumper cable became hot..(saw some smoke)
-key was not inserted
-relay checked with multimeter..seems ok.
conclusion1-starter relay is not the culprit.
now im clueless...
something wrong on the wiring? other relay?switch?
please help.. thank you
(im in pasir gudang, johor)
now im clueless...
