salam n gud afternoon guys
i need help for upgrading neo sr 16 vvl
its seem to me quit same with vtec which i familiar but
not improve much...
plese help me...
for now i wanna to upgrade for street use
maybe on saturday night have little drag with friend at johor circuit
for now i already upgrade fuel pump,fuel regulator,extrctor complete piping,hks air filter open pod,exedy clucth.
do i need to add adjustable cam pulley?
is it possible for 16ve cos using timing chain?
basically for SR16VE that the stuff you have upgraded
except engine management and suspension handling as well aftermarket LSD
unless you go crazy power like N1 spec then you should go ahead if you have the $$
most of my friend that has at least the same mod like you. goes for 2.3 inch.
there are some that goes for 2.5 inch.
if u ask me, my opinion is to go for 2.3 inch (taking the mods that u done, in consideration)
but if u are thinking of more mods to come...eg: piggyback..straight forward go for 2.5 inch.
neovvl engine loves to breathe..the more u tweak it..the more it breathes..hahaha
cmng uses 3.0 inch for his 20ve converted to manual. B14
and even there's one person who uses stock 20ve with stock CVT gearbox, use 3.0 inch piping (with mods off course..) Y10
Lopi
you should focus on what you want
handling or power
if you want both together then the whole car setup is different
upgrading one by one is good but that is time consuming and spend more $$
i have my own focus
i want handling + a power that more than enough to play with many car
hench i focus on my handling part and left the engine stock with proper exhaust setup only
since i know 2.0VE + 16VE gearbox power is more enough for my requirement
so brake setup, suspension and rim and tire setup is my priority
i not sure what you want.. some people want to drag, some people want to track
so it will some with different setup for it
ops sory bro cmng.
like i said i wanna upgrade for street use and sometime go 'test2 power' with friend.
for now my tire is Toyo T1R,my rim is advan tc 16,my absorber is tien super street.
i also use ultra racing bar and auto foam for straining my car body.
so i quit satisfied with this.that why i focus on engine now.
but i still need suggestion or info from you guys.
1. street use
2. occasionally 'test power' with friends.
i presume that your aim is to have a car that can smoke majority street cars whilst having the pleasure of friendly competition with friends..
stroke your engine to 2.0VE. its the best and suits your requirement.
source parts from cmng. he can help u.
he's the right man to ask, vast experience with SR20ve manual inside B14.
Hey guys, i just want to know the specification on this meters listed below. just to have a sure confirmation.
what is a:
-vacuum meter
-water temp
-oil temp
-oil pressure
-fuel pressure
-air fuel ratio
-exhaust temp...
