HELP ME!!!..
i got a problem for quite sumtime now..
i'm using SVT R12 gas type aircond..
not sure what is faulty.. if connect this aircond plug, the aircond light will blink..
so, my mechanic bypass the plug using a wire..
i suspect its the temp sensor..
any1 have the same problem?
bro, I also got this problem intermittently. The aircon light blink. Then I turn off aircon and turn it on again the ok. Donno what the problem
Our SVT model temp sensor located dash cover at left bottom under steering right?
I had a gas leaking problem last time and i don't detect any light blinking le.. I think this is due to compressor fulty.
i thought you've changed to R134? i came across with 2 different situations with AC light blinking:
1. i run over a deep water 'lopak' and it splashed the compressor then suddenly i feel my steering jerking and AC light blinking. then my AC not cool anymore. but this is temporary then it back to normal after OFF-ON the AC.
2. i had a leakage between condenser - compressor, then the light is blinking. fix the leakage and pump in gas resolve the issue.
does the blinking has a code behind? like our ECU faulty code? hehehehe
HELP ME!!!..
To be frank, i will get mad if the mech do this to my car. This will not solve the problem but create another trouble to our belove ride. I would suggest you to reverse back the modification and find the root couse. Otherwise, you will have to compromise with this situation, until you sell your car...
