- Joined
- Jul 10, 2004
- Messages
- 987
- Points
- 3,028
Nicely explained ... cool ...
a few more questions to share ..
1 - I am using as RWD with T50 gb... must use the speed sensor ? ... it will be a hassle to convert cable to digital ...
2 - Tuning can be done with TPS or MAPS only right ? .. cannot be both ...
3 - I need the below items
- Haltech S500
- Wiring works
- Cam installation
- Engine tuning
Basically that is all right ? ..
thank you very much to all Sifus for the valuable advise ...
1.You can use speed sensor IF your speedo is the electronic type(20v svt/bt).No problem converting,my 20V KE70 with T50 also use speed sensor+SVT meter.
2.For Platinum series Haltech,tuning for fuel can be both,TPS with MAP compensation,but for Ignition only can be either TPS or MAP.This is not a problem.
3.Yes basically thats it if you already have other things,and you need ballast resistors if you want to use Sprint500 on 20v because the S500 cannot support low impedence injectors.
