Never use air pressure below recommended. Tyre heats up more.
I think exhaust shop guy maybe wants more traction. More air pressure means over inflate will have less traction, but car will be lighter. 40psi all round is for track, but we have tried standing start before and find more air pressure is faster. You can also trial and error with different settings. Maybe bro. pomen mention of only more for rear works, as we tried all four same. This is where the fun is, trial and find the best......Car lighter with more air pressure, but less traction, therefore once you can control your initial take off with the least wheel spin, the pick up should be faster...
i dont understand. so can i tell him 40psi for all tyres? what is psi btw? is it a unit to show the how much air to pump in to the tyre?
Different cars have different torque, so you have to find yours. You are correct to play around the different range and see how it response. The main idea is not to wheel spin as this loses time and traction. Using the clutch to control so you can get into the higher power revs also good, but once you control the wheel spin and car is launching, you have to fully release clutch for best contact and at the same time keep the engine revs up. Once the revs fall it takes time for it to come up. All have to work hand in hand....
When i revved to 5k rpm, this is what i think happened. i didn't release the clutch fully. when its on high rpm and i release the clutch won't the tyres spin.
bro AD_EG... got ur suspension setup theory... wat i heard was different le... for FF cars, front should b softer n rear should b stiffer... reason is simple, coz when u launch, ur rear will squat, so making the rear stiffer will ensure less squat happens when launch... as for the front, putting it softer coz when launch, the squat will cause ur front to "lift off", softer suspension will let ur front drop faster thus getting the traction... tis is the explaination that i've got n accepted... hope my explanation is understandable.... heehee
for tyre pressure... i was pumping 40-45psi on my 15" R1R.... grip all is good... using on a wira evo.... lauch at around 3-4k rpm.... but cant full throt on first gear... only 2nd gear n above can hentam.... FF turbo... sigh....
bro ddv_nk12... i suggest u dun control ur clutch when u r launching at high rpm... u'll "goreng" ur clutch... althou it really feels much more powerful to launch like dat... rev up a bit... allow a little of wheel spin when u launch... then control ur throttle.... sure bro ad_eg can giv u tips la... he's vtec kaki...
Get slick or semi slick tyres, but not for wet, only for dry tracks. Pump at least 40psi pressure.
Disc pads at least 800 degree type, if not brakes can fade or fail.
Got mod suspension or not??
wow... din know pasir gudang night sprint getting famous... damn long din go d...
but to TS, ur bf is going for night sprint or other events??? i checked PG website, today n tml was booked from 9am to 5pm... so might be some private event???
but if he's goin tonight, then i'm quite sure he's goin for the night sprint the guys were talking abt here...
anywya... all my dua sen... damn long din go... since i sold off my wira evo....
as far as i know, mostly the race team using full slicks in Malaysia run averagely bout 22 psi. check this out..hope u enjoy it.
www.scribd.com/doc/25197303/Michelin-Race-Tire-Catalog"]Michelin Race Tire Catalog
and this
PROXES R888 | High Performance Competition Tires | Toyo Tires
click on "set-up and care"
