Evo9 Steering Vibrate at 230km/h
only happens at lock-to-lock eh? sounds like a loose belting jer
Ya lock-to-lock.. Which belt? Serpentine or timing belt?
Eh, wanna ask u guys, is it normal when full turn lock-to-lock L/R, u wil hear air hissing sound?
the belt connected to the power steering pump, check dat.. come to think of it, ive even experience it after tightening the belt, but only at lock-to-lock position
check your tyre carefully....otherwise your steering rack.....
If tyres or rims, I think can feel when I accelerate at 120km/h or when pressing brake, right? I tested 180km/h, nothing happen, smooth like airplane auto-pilot..lol..
I remember I once went to do my alignment, and the guy said my chamber position is not match, and cannot make both side match, he then try to measure from fender to tires length. And guess what, he found out that front L/R is diff length with each other. And he checked whether I've accident before, and no. The soldering is too neat, no odd shape. Maybe before the car export from japan got accident or not I dunno la, u know la japan technology.
So my car, no matter how the chamber was aligned, it won't match L/R. one side sure lari a lil bit. And my car sure go left when I didn't hold steering and put it straigh even after alignment.
I'm using diaqueen wor. And, the last time I change fluid was like 6 months ago. Have not do anything beside normal service after changin the PS fluid.
Ok will do. Thx :)
U meant yours also got air hissing sound??
Previously a weird sound that appear only during rain, and the sometimes when cold start, can hear the rattling sound (metal scratching) underneath the car for like 3 secs?
And then free racing clutch sound "either alternator or some other component bearing worned".
And vibration at 230km/h.
And now steering got cicak sound..
Aduuhaiiiiii.... all the prOblem so rare one...
Evo IX Weird sound during rains. - YouTube
watch this guys and help me to figure out this sound!
It only happen when raining, be it dizzy or heavy rain. And is not WATER SPLASHED! It happen during cruising at low or high speed, and even idling.
Sounds and vibration can felt it from the mid console/handbrake part. When it rattle, even my gear knob also can feel the vibration.
I hv never encounter d problem u mentioned... Been riding d 9 for more than 7 years now... No such vibration at 230!!! Hmm... So i think its best tht u send your car for thorough check especially d steering system including d pump... Cos it really sound weird tht it onli happened once u go over 230 but at 220 things r all fine n normal!!! U need a fit car to drive fast, so send for check b4 u have another go!!! ^.^ Cheerz~~~
Ok will do. Thx :)
The rattling metal sounds due to this x bearing thing below (forgot its name), refer pic below. Changed mine last time, and the rattling metal sound gone. Its related to the front belting..price quite cheap (forgot the price and where bought it)
As for the speed vibration, go and check your drive shaft..
Where is it located?
Is it the bearing from the long shaft? I recorded the sound few times with success, and i showed my mechanic when we come out yam cha, and he said should be the long shaft bearing. but haven't check on it yet cause busy with work.
The speed vibration....I done 240+km/h that day and guess what, nothing happen d...I tested twice by released until 220 and tried again til 240+, nothing happen...zzzz
i had same prob as ur evo, my e7 sound like as u describe during raining. it sound exactly the same as u posted in youtube...i still havent found any solution for that prob, some ppl said it cause by aftermarket exhaust system, some ppl said it cause by the longshaft bearing, some said because of the drive belt tensioner....
Finally i found someone who had the SAME problem with me.
Yeah i've search through here, evom, etc, and all i saw was either the
-downpipe
-catalytic converter (don have for me)
-some loss-bearing
-some loss nuts
-heat shield underneath (don have for me)
I'm going to check mine very soon enough when i'm free, probably tomorrow, i hope so....and will keep update you here so at least you will know where to start :).
clanzkiller,
I also dont have the heat shield underneath...
I think its not related to you problem...
No weird sound problem...
