sell to me ur svt meter then.. hehehe
mine about RM500, no need 2 change meter..
is tat any diffrent between power? how much u bought bt wiring tat time?Why don't you try to use simple trial and error solution first. For example to change ISCV, just cost RM50 only.
Alex, your aircon compressor already converted to proton model, and all the compressor's sensor/sw to the aircon controller/ECU already disconnected. You change to BT will not resolve your problem. Better you spend small portion of your budget revert back your aircon system.
but my aircond syestem change it 4year ago and it wont kacau my idling...my problem is not open aircond oso RPM down to 400-500rpm wor![]()
bro, how about ur distributor angle? did u try to adjust the angle?, ur spark plug cable using what type? did u have manage to measure each spark plug cable resistance value? still can good connection? ur compression ration for each piston?
normally the idle issue occur during cold start or already warm out the engine?
-try adjust oledi,oso same !!
-plug cable normal (dono how to measure spark plug cable resistance)
-compression ration for each piston not check
-idling issue normal or cold start oso same( but sometime in a week it got 1time the idling will back to normal for short time!! mybe a few minit or hour then back to worse![]()
bro,
the measurement of spark plug cable just need to confirm that cable having connector from end to end each other.
as u saying, idle will be weak till 400 or 500 rpm. then is that ur engine have suddenly die? then ur O2 sensor have to attached at exhaust manifold there? what is the size piping r u using?
how long r u check diagnosis? did u have copy? then u try to upload here and share with us. maybe can find out the roof causes.plug cable check oledi it had conect each other...ya engine will die !! i had done dianosis( all sensor ok) i use 2inci piping
Vacuum is leaking somewhere...
You can buy and install vacuum gauge to monitor the vacuum. Good vacuum i around 17-21 hg
http://www.freeasestudyguides.com/graphics/vacuum-readings.gif
They tried to put the blame on my tuning but did not even bother...
