jonlsl
Yup, price slightly more only but difference so small. For me, Bendix Metal King Titanium cost RM100, so for me is RM5 difference only, but the friction is so much better, and I drive with more confidence.
For slowing down process, I just have to tap on the brakes. The other day following a car who suddenly brake at around 120kmh, with a slightly harder tap, and I could lock my brakes....
Trestor also have semi metallic pads which I think is same grade as BMK Titanium. I ask PH Auto boss, and he said Advantage Blue is higher then the semi metallic. I use also with recommendation from AW member who had used before.
Of course with pros there are cons also. With higher friction the brakes rotor runs hotter, so much so after a run I can feel by touch on my rims then they are much hotter then the time on BMK.
Due to this much more brake dust also. In a week the rims are already covered dark, almost similar to BMK runs for 2 weeks.....:rolleyes:
Does the new pad look as "rough" with metal fibres like BMK?
