Brembo Brakes Cover
Yup, price slightly more only but difference so small. For me, Bendix Metal King Titanium cost RM100, so for me is RM5 difference only, but the friction is so much better, and I drive with more confidence.
For slowing down process, I just have to tap on the brakes. The other day following a car who suddenly brake at around 120kmh, with a slightly harder tap, and I could lock my brakes....
Trestor also have semi metallic pads which I think is same grade as BMK Titanium. I ask PH Auto boss, and he said Advantage Blue is higher then the semi metallic. I use also with recommendation from AW member who had used before.
Of course with pros there are cons also. With higher friction the brakes rotor runs hotter, so much so after a run I can feel by touch on my rims then they are much hotter then the time on BMK.
Due to this much more brake dust also. In a week the rims are already covered dark, almost similar to BMK runs for 2 weeks.....:rolleyes:
Does the new pad look as "rough" with metal fibres like BMK?
When I went for a test drive on the VW the salesman
totally shutted up any can feel his hands is trying to hold on to something. Jam brake the car as well... The moment I step down I could feel that he's got an opinoin of my driving. Later I pulled out my cheque book, his face changed again.
Breaks passed. Don't need to change or up grade. Just hate the colour of the cover only. Above all I'm going to change the rims. Pls comment there at my other post on my selected rim. SiFu's advice needed...
From your post means lucky the salesperson did not pee in his pants.....hahahahahha:rofl:
Do you mean the brake caliper color, as there is not cover. Just get the high temperature paint and paint to the color you want.....:driver:
