- Joined
- Sep 17, 2008
- Messages
- 20,674
- Points
- 1,713
Transplant 1JZ...
engine is still the same, u want more torque of cause u will loss hp, more torque more pick up, more hp more top speed, everything will be balance unless u modify your engine. For me, i will not use LCP anymore, my friend use LCP crack 2 units in one year, even use branded.
Sorry, unless you are talking about a diesel engine, this is just plain wrong. Hp is derived from torque, so how can they have an inverse relation? :rolleyes:
Is true, you can't have both Torque and HP increased at the same time. If u want more top speed,
you have to sacrificed some reduction in torque. You want more Pick up/torque, u have to sacrifice
some top speed.
HP = Torque x RPM ÷ 5252
Let me break that down for you in simple terms. HP is a function of Torque. When Torque increases, so does HP, vice versa. You can't say I want my HP to increase by sacrificing some Torque, that's not the case according to the equation BECAUSE HP is derived from Torque.
Faham ke?
some mods increases horsepower but decrease low rpm torque.. example bigger exhaust system
some mods increases both horsepower & torque.. example spark plug cable
some mods change the characteristic of horsepower & torque.. example camshaft
LCP is 1 of the mods that increases both hp & torque (i think)
it's complicated.. so, know what u want 1st.. only after that, do the mods
happy modding![]()
i personally think auto car is good pairing with LCP. as mentioned, pickup, acceleration,torque increase but your top speed will be lowered.
come to think of it, if u r so kaya to pay all the summons when u r top speeding nowadays, then u sure will have extra money to test out LCP haha. mytheology lcp is xpensive, but sez its dampen, so absorb vibration etc etc.have not tested them
raya coming, dun rempit laju laju
Yup, of course. One simple mod isn't gonna make gains all throughout the rpm range especially light mods like IHE, but I think it's reasonable to assume replacing your header with a good aftermarket item will make gains over stock across the rpm range.
Anyway, it's OT anyway. LCP reduces rotating mass, not make more power. It helps by getting your car across the rpm faster, so it seems like you have more torque, which you don't. It's like making your car lighter. You don't gain Hp, you just make the ones you already have matter more. Underdrive LCP however, is a different story....
Got your point.
K guess got some correction. I meant if want to increase low end power, then have to sacrifice top speed, if want top speed, then have to sacrifice low end power as in pick up...
So, is like telling the mech, I want to increase the pick up/low end power of my car but I also want to be able to maintain the top speed/High end power. Just not possible.
Sorry wasn't clear with my description. :rolleyes:
