- Joined
- Sep 17, 2008
- Messages
- 20,674
- Points
- 1,713
Actually if you compare disc brakes and drum brakes, drum brakes have more contact surface and bites better then disc, but because drum brakes are enclosed they heat up fast and braking power fades. Brake dust also accumulate inside.
Disc brakes however are open and cools faster. Those ventilated ones have groove in between for even better cooling, therefore overall Disc performs better.
If you can brake to lock and your car skids then you need better tyres.....
They might just clean the inside, sand down you brake shoes and then fit back.....:rolleyes:
Silverstone that time was terrible, even my sister drive also say skid a little and got screeching
sound when cornering...so XM2 better not too bad..but still not good enough in terms
of grip. Daily use okay la...
No wonder always got sound la...Celaka betul...but if the replace the drums should be able
to see is new like my new disc right?
My brake disc the change for me adi...thought sound settle...then still same...that time
do major service.
I wonder if anyone out here can advise on the...
