Taikos... m-o-d-i-f-i-e-d filter.
I used to own a OCT but stupid me sold it. Now I'm too scrooge mcduck to want to buy another one.
No doubt it may trap oil. I don't dispute that. It's just the loss of vacuum that I worry is being overlooked. If your filter paper/element gets wet with oil, you lose vacuum. If your filter container gets filled with oil you will also lose vacuum. With this loss of vacuum your PCV system isn't really working to bring air/gasses out of your crankcase. This means your oil flow rate to your bearings is compromised. Your main and conrod bearings are probably suffering and you may not know it. Yes, your engine works but do you really know how well your bearings are doing now? Think about it - don't you think manufacturers would have added a RM6 filter for this system if there were no risks involved?
Well, if any of these DIYers are like me, I have about 15 of those RM6 filters at home and change every month or so. Other times I just pour out the oil. And since my filter doesn't have any paper elements, I think the vacuum loss for me is minimal or none.
Just recently I inspected the hoses and the filter and found that the clamp around the filter wasn't completely sealing the connection between the hose and the filter so I could hear some vacuum noises there. Seems the rubber hoses will crack and become brittle over time. Lesson learnt is buy good hoses.
For my Hyundai, the link is from the left nozzle to TB. The right link with PCV valve I have added an air leak device and yes I do check the filter regularly. The oil caught is very little only and once the bottom of the filter has oil in it, it is changed....
Taikor, what air leak device are you using? pressure gauge?
And you said that u change the filter when there's oil at the bottom of the filter...did u mean the small reservoir below the filter? Mine has catched some amount of oil.. 2ml like that. Dont really knw when to change unless open up the filter and see if it's clogged. Even so, I need some gauges to do that :hmmmm:
Um... I change it every 20k km. But even then it's barely 1/4 full
I just use a RM7 carb plastic fuel filter as my oil catch tank.....lol
Give you something to do. Plastic carb one nothing to do, just hook up.....lolMe too bro, I used the iswara fuel filter like how izso did .
Thinking of doing this on the Vios dugong lol.
Hey Guys,
Anyone knows where to get these parts ?
It's to make an oil catch can.
http://www.team-bhp.com/forum/diy-do-yourself/117722-diy-cheapo-oil-catch-can.html
Elbow fitting
Pneumatic press fit elbow fittings
And the black colour glue this guy used.
JBWeld you can't buy here. Superlon black coloured sealant might work but I'm not sure how it'll hold up in engine bay heat. And if you're gonna make this skip the indicator as that's usually the biggest culprit for vacuum leaks.
I never understood why engine manufacturers routed blow-by gases back into the intake manifold. All the oil vapour (read : Oil) gets trapped there and completely clogs the throttle body and intake manifold causing sluggish performance, inaccurate idling and in some cases engine dying off due to overly low idling.
In order to counter this problem, some budding aftermarket enthusiast created the Oil Catch Tank (OCT) and connected it to the PCV valve catching all the oil vapour therefore keeping the intake manifold relatively clean.
Picture taken from ZTH sales pages, copyright and all belong to the owner, not me
So I was thinking, is there a DIY-er way of doing this OCT without spending too much? Yes there was.
Tools needed :
1. Iswara Fuel filter
2. Automotive rubber hose
3. Clamps
Locate the PCV valve in your car (usually it's a rubber hose going from your cylinder head going into your intake usually before the throttlebody).
http://farm7.static.flickr.com/6128/5932301292_46e7b14676_z.jpg
Replace this hose with your makeshift OCT and you're pretty much done.
The Iswara fuel filter has paper filters in it which will trap the oil vapour (read : Oil) and collect it in the filter. So be sure to replace the filter once it fills up (eventually). RM6 bucks give or take!
Enjoy!
Disclaimer : I've only done this for my Wira, Myvi and Toyota Unser without adverse effects. I do not and will not claim that this works for all car makes and models
is this the breather hose for the myvi K3-VE engine ?
shouldnt we route the breather hose to the oil catch can as well if the article says the breather hose also has blow by gas.
lol, i'm in need of experts opinions.
I dunno. The leak I've usually seen happen is where the indicator is connected to the can itself.What if the indicator instead of using the press fit type but the one like the brass elbow fitting wan like the one on top.
Is it still possible that it's going to leak ?
