Correct mah.....
The total diameter is almost the same, so which one is heavier as a total package?
I think the iron rims is heavier..What tyres are you using with size 195/70R13? Largest in 13" 70 series I have seen is 185/70R13.
And 215/45R16 also very rare. If not mistaken mostly in extreme tyres
I might be wrong.. Maybe it's 185/70/R13 and 205/45/R16 I'm don't quite remember.. Using Nankang N2
ahh i see.. by upping it like that will the FC increase?
If the width up 20mm but diameter is of correct conversion should not increase FC. Even increase should not be much...
Bear in mind, its 20mm per tyre
Total 20mm X 4 tyres = 80mm additional tract & rolling ressistance...
I can only agree that it will increase FC, but the amount of increase is questionable....![]()
how about this.. Iron rims 195/70/R13 to Rays TE37 replica 215/45/R16.. will it increase?
i see.. i tried it before.. front doesnt scrape fender on full turn and rear doesnt scrape on full load too..
