So here my situation about a week ago my car tempreture went high around 70% of the gauge.. When i saw this i suddently stopped my car
Then when i check the radiator resevoir tank it was empty so i add water and same goes to the radiator
Thinking no harm done so i drive Away and the gauge seems pretty promising while it only showing only 40%-45%
Then i remain to check. The next day i check the resevoir tank was a bit crack on the screw part so i glue it.
But here goes the problem. The water level keep decreseing. And it took quite a lot .. I move around 40km and my resevoir tank was only around 60% from full indicator.
There is no water leaking on the ground. And when i proceed to check the motor oil thereis no milky substance .. As motor oil + water
Fyi my car only with water and no coolant .. I scare when i put on coolant it will scrap the rust away and make my water pump or orther part worsen
Ive also done bleeding air from the system and to be honest the water is quite dirty and currylike colour..
i even cant saw this car in Auto saloon 2009...
