- Joined
- Sep 17, 2008
- Messages
- 20,673
- Points
- 1,713
Try CSM hardware in Shah Alam. I remember seeing the 3000 grit if not mistaken.
Anyway, yup some use up to 2000 only as that is pretty fine already, then follow up with polish...
---------- Post added at 07:54 AM ---------- 6 hour anti-bump limit - Previous post was at 07:53 AM ----------
If yellow then no need sand. I mention peeling. Some headlamp can see top yellow layer peeling away from the main plastic, then to remove need some wet sanding...
Mine if look closer, can see some fine lines of cracks inside...is not exactly crack but there are lines that form the likes of crack lines...
