- Joined
- Feb 8, 2007
- Messages
- 474
- Points
- 1,543
Hi,
i hv this '09 perodua nautica, a CBU from Daihatsu Terios 1.5 4wd, of my father in law that has to replace its compressor + condenser. problem is the car so rare so the parts is so hard to get. i went to a/c wshops around and they keep shaking their heads. reason being was the part is not available. this car uses 1.5 3SZ-VE similar to Alza, Avanza, Rush. but the air con unit parts has slightly different here n there. nautica uses 6 grooves belting or pulleys. last wshop i went said cars i mentioned has 4 grooves only, even the compressor fits nicely. change the pulley is not an option because i know it will bring problem in the future.
i asked perodua, they dont have this parts, they have to order from daihatsu and the price would be high like shit. i called toyota and they said Rush is indonesian assembly so shah alam doesnt have the parts. but toyota came up with "according to the code u gave, it is similar to avanza's, but not sure..". this tires me.
i also like some advice if i can use Rush's condenser. the nautica's condenser doesnt have plug to drain refrigerant...it sealed..welded.
i am in a need of favor from u guys. pls somebody let me know if i can use Rush or Avanza compressor, bcs many pomen say cannot. any advice or anyone knows any nautica user that has solution, pls let me know.
thank u guys.
ska
thank u guys.
ska
