- Joined
- Mar 15, 2006
- Messages
- 1,509
- Points
- 1,683
i think easy way is get a real track car like Radical Sports Cars
Another restriction will be Satria to 2.0 engine. Perdana original is 2.0 therefore is okay
Why not save up for Evo 3?![]()
A31 chassis heavier, Unless is a Nissan Bluebird with RB26DETT, if not wrong one of my friend's friend transplanted that. Cant remember is RB25 or RB26.
Still a beginner only in this forum but other forums I'm not sureKidding.
Like 1.8 Celica GTS engine transplant to 1.8 Corolla![]()
If getting those Satria with endorsed 4G63T and I replace the engine with another 4G63T from halfcut, is that still ok?
The price of Evo 3 is almost the same with Evo 4 or 5 already now. If I had the money for Evo 3, by that time I would probably consider Impreza GC8 also since I liked the boxer sound, lol.
This is the only car forum I have joined, lol. I'm just 20 years old only, how much can a 20 year old know about cars compared to all of you here who are older and more experienced.
From what the TS replied, it looked like he is trying to get a budget car. Radical Sports cars are not cheap...
Some members here started to show interest in cars during secondary school days. You will get
to know him soon, lately he no online only![]()
GC8 got one for sale on ZTH, but this one is 4 door ones.
I think a budget project car, is still the Satria Neo R3, Clubsport definitely not easy to find or
no one is selling it.
Once you replace you will have endorse again....
How about a B13 Sentra with a SR20VVL? Those are pretty quick. Or an E30?![]()
Sentra with SR20VVL is really a monster. 4AGE totally no match for it...
Yeah and these days they're quite affordable... heard they handle well also.
But chassis rigidity cannot compare la to newer cars haha.![]()
I wonder if you guys know Mike Kojima and his Sentra.
http://www.motoiq.com/magazine_articles/id/1411/the-dog-ii.aspx
Engine Code: SR20VE
Type: 1998cc in-line four, aluminum block and head, variable valve timing and lift
Internal Modifications: SR16VE N1 camshafts, Jim Wolf Technology adjustable cam gears
External Modifications: SR16VE N1 intake manifold, throttle body, Advanced Street Performance custom exhaust header, Technosquare custom exhaust, air intake, and oil breather system, Burns Stainless muffler, Ford Cobra MAF meter, Jim Wolf Pop-Charger air filter, Unorthodox Racing underdrive pulleys, Koyo aluminum radiator, Setrab oil cooler
Engine Management Modifications: Jim Wolf Technology re-flashed ECU
Drivetrain
Layout: Transverse front-engine, front-wheel drive
Drivetrain Modifications: Jim Wolf Stage 2 clutch, flywheel, and mounts, B&M shifter, Energy Suspension urethane shift linkage bushings, Nismo 1.5-way LSD, 4.4:1 final drive gear, gears cryo-treated by Technosquare
Suspension
Front: Advance Design adjustable shocks, Eibach springs, Progress swaybar, Technosquare custom reinforced control arms, Energy Suspension and Super Poly Pro bushings, custom front ball joint adaptors, outer tie-rod ends, Ground Control camber/caster plates
Rear: Advance Design adjustable shocks, Eibach springs, Progress swaybar, Technosquare custom panhard bar, Energy Suspension bushings, Shigspeed spherical shock mounts
External
Front: Fastbrakes brake kit (four-piston fixed Wilwood calipers, 11.7-inch two-piece rotors, stainless-steel braided brake lines), Performance Friction 01 pads, Altima 1-inch bore master cylinder, Tilton adjustable proportioning valve
Rear: Nissan Maxima rear calipers, 11-inch rotors, Fastbrakes stainless-steel braided brake lines, Performance Friction 01 pads
External
Wheels: Volk Racing TE-37, 17x8-inch
Tires: Nitto NT-01, 235/40/17
Body: VIS Racing carbon fiber trunk and hood, GTP rear wing, Stillen airdam, Afterhours Automotive custom carbon front splitter, rear diffuser
Interior: Technosquare custom roll cage, Sparco seat, steering wheel, pedal set, Stack dash display, Safecraft fire suppression system, Odyssey batter, Password:JDM battery mount kit, Afterhours Automotive carbon fiber dashboard, lexan windshield and windows
Sourced from some other site.
I din't know Sentras could be this awesome before I saw his car. But still, for some reasons I just don't like FF layout vehicles.
Take Ford Focus RS for example :top:Satria / Putra 1.8 4G93 can be stroked and rebored to almost 2.2L. Ok what. Cheaper than Evo engine I think
If the 4G93T is stroked and rebored, can it offer similar output with 4G63T?
There are still the good old 1.6 litre high revving engines. 4A-GE, SR16VE N1, 4G92 MIVEC and B16B. Why can't the new engines offer such power as well...
Because modern people and the high cost of living, many are now focus more on FC and what
is value for money. No longer looking at power or performance but how long can the
car last them and how far can the car take them in terms of FC
Wow, what's the output? :stoned:
FF cars easy to controlTake Ford Focus RS for example :top:
That means I need to stick with the old engine and cannot replace it with a newer one...
You can replace but every time you replace got to re-endorse.....:rolleyes:
---------- Post added at 07:54 AM ---------- 6 hour anti-bump limit - Previous post was at 07:36 AM ----------
A JWT programmed factory ECU handles the task of engine management. Other than these external bolt ons, the engine remains internaly stock. Stock or not, it pumps out 200 whp and 153 lb/ft of torque an impressive sum. In the future a sleeved big bore, long rod bottom end, higher compression and headwork are in the wings as is future cam development with a goal of 230 whp.
This is on page 3...
---------- Post added at 07:58 AM ---------- 6 hour anti-bump limit - Previous post was at 07:54 AM ----------
They mention Nittio NT-01 tyres but picture is Toyo Proxes RA-1 tyres?...:hmmmm:
