6a12tt-rs.perdana v6
Caldina seat very expensive......no budget...hahahaha....
Guys how bout vr4 rs seat is comfot? Price RM 600....
send form samsung galaxy tab tapatalk hd
better get the galant seats, just plug & play, for vr4 think u need to mod the subframe.
My engine has a wired sound like screeettt..!.screett!....Im heard at timing belt....whatbwas that?...its a bearing...?
Throw bro throw..haha...for sure you will satisfy with the sound and the performance...I dont use that and so far it gave me better performance at high boost and better fuel at low boost...
But for sure the sound will be more louder la....:burnout::vroam:
hi, mine 1/3 part of front use 2.5 i think, the rest 3 inch. No midbox. A little loud for my liking even cruising on hiway. The droning is there even not tekan alot. But when TARIK like teh tarik, the noise is even softer.
So im thinking to find those evo stock muffler or maybe ori v6 muffler to further soften the noise. i think serba sedikit the performance will be affected as the boost masuk quite cepat at this moment. not sure on the effect of fuel consumption. Also with the restriction on tail, i think it will hurt the turbos since the gas not going out fast enough.
http://img.tapatalk.com/d/13/06/04/e6a3esug.jpg
http://img.tapatalk.com/d/13/06/04/my2u8a6e.jpg
my car have been repaired.......
now ekzos from front to end 3 inch non middle muffler...O.M.G the sound....i feel love with his sound......
now the problem is the blowoff dont make any sound...i have been adjust but stiil dont have sound why aaa.....i am using standert air filter......
Sent from my GT-I9300 using Tapatalk HD
---------- Post added at 10:51 PM ---------- 6 hour anti-bump limit - Previous post was at 10:41 PM ----------
http://img.tapatalk.com/d/13/06/04/ejezu4y7.jpg
---------- Post added at 11:20 PM ---------- 6 hour anti-bump limit - Previous post was at 10:51 PM ----------
http://img.tapatalk.com/d/13/06/04/aqe4ydub.jpg
got install boost meter? Any difference in the reading from previous and current piping?
air filter stock or open pod no diff.
no boost meter was install...my previius engine just install emanage only....
got diff when install the pickup & top speed.. the respond is very quick then previous piping...my previous exzos just 2.5inchi borja middle muffler....what the impotant is the sound it make very loud sound.....
were can i find auto gearbox oil filter twin turbo 4WD eterna.. I find a lot of shops do not spare..
did u bring the ATF filter to the spare part shop for them to compare?
like mine (RVR turbo auto), i dono the parts code, so i bring the ATF filter to sparepart shop, then the find suitable one for me.
mine looks like yours la..
Hi,
I recently converted my E54 Galant from 6A12 to 6A12TT from E84 VR4.
Has anyone here run custom front exhaust pipes from turbo outlet an had any good gains in power?
I notice that mid range power is good till about 5k rpm, but engine does lack top end power. Mine is manual version with blue tab TD025 turbos. Everything is stock at the moment.
usually good custom exhaust job will have power gain.
how good it is depends on the work.
with turbo, u can go bigger, but not too big.
i guess the down pipe (not dump pipe) can be as big as 2" and the exhaust go for 2.5".
better ask Danzeterna as he's using TT engine, i'm on a 4G. hehe..
for the top end power, u might need to tune back the engine and find the best AF ratio.
maybe the fuel is too rich or too lean..
---------- Post added at 02:57 PM ---------- 6 hour anti-bump limit - Previous post was at 02:56 PM ----------
screett sound might just be the belting (alternator or aircond) is too loose or too tight.
or maybe the belt needs replacement..
neuroone..tq your info..but can u suggest me any sparepart shop..i try go there to buy this filter.
pozy,
theres a sparepart shop right in the middle of pekan kajang.
u have to order la..
put this coordinate in google map: 2.992384,101.788204
Guys im install 220km/h meter before this 180km/h meter...220km/meter that rpm meter read 2000rpm @ 80km/h..180km/h meter read 2000rpm@70km/h...why aaa....that 220km/h meter not suitable? :what:
Sent from my GT-N7100 using Tapatalk HD
check with gps first which one is accurate kmh.
and both meters are from 6 piston engine?
Yup both meter from 6piston...I dont trust the gps...coz gps late bout 5 or 8km/h....
actually, GPS is the true speed.
our meters - cars, bikes, lorry, bus, etc is calibrated slower.
our cars, based on my observation, slower by around 3%.
thus, if u are travelling at 100kmh, the GPS would read 97kmh (this depends on the original tyre size).
that is why when u change to bigger rims and fatter tyres, there's this +-3% diameter rule.
what i mean to try both meters with GPS, as to eliminate speedometer problem.
Oh I see....but that meter was okey all function.....my pomen says that meter its ok nothing to be affraid but im still... confius.....that 220km/h meter is light or that meter is 4g93 galant@eterna hmmmmm?.....im using 235/45/17 tyre....
235/45/17 is about 1.77% bigger than 205/55/16 (Perdana ori size).
based on that, at your meter 100kmh mark, the GPS reading should be around 98.7kmh~99kmh.
Thks neuroOne......I think I just use that meter..now what im thinking is the piggyback....any want use unichip? Can tell me bout this unichip got pro n con?....
Last saturday I follow my fren buy this unichip...install+dyno O.M.G....the hp power up...before install bout 195.6hp but then install unichip the hp up to 279.9hp...my fren engine only install evo intercooler only....
