I saw 4B11T. :top:
Sorry, off topic a bit.
Agree with cvKit17... Further more.. this DIY is so cheap.. if don;t like, can just remove it...
The only negative thing I can think of is IF the hose burst, it is hardly noticeable.. But yet again, how often you hear someone's aircon hose burst :P
welcome back johnsonlam, so you moved on to Evo?
Burst no, but leak have. Yup, have to open to check, but then mostly leak at the joints....![]()
aircond temp will effective drop 1-2 degrees...
Don't aircon system runs on expansion theory? Compressor compressed the fluid thus higher temp, goes into the cabin pass the expansion valve, expanding fluid absorbs energy ie heat then cools down surrounding air(in the front of the blower) thus we get cool air. Cooler but expanded fluid now goes back to the compressor to be compressed again n the cycle continues. So in the engine compartment, the cooler pipe is actually output from the cabin n the hotter pipe is input to the cabin.
Done this to my daily ride. Even covering all the line up to the valve. Material : Plastic cover bought from Ace Hardware and aluminium
cover which cost rm5 bought from Daiso. Has some insulflex stuff which I plan to use on the hot spot.
Result : pretty cold at daytime. Using cheap tinted but level 2 with mid temp setting during hot day is sufficient with 4 person
on board .
Almost not usable at night. Set at level 1 with the temp shut down also still very cold. Have to close the air-con panel.
Will take a picture when I am free.
can anyone recommend a seller who sells insulflex in tube form? i can't seem to find anybody who sells in small volume
PM me, thanks!
