[DIY] How to decrease engine bay temperature
me2kimi
Puchong
Hi all DIYer's. This are the method that I make to decrease engine bay temperature.
I don't have original picture, so I just grab it over the net.
1- Wrap extractor- engine bay temp significantly reduce after install this.
http://cache.allexhaust.com/images/site/exhaust-wrap.jpg
http://carphotos2.cardomain.com/images/0016/20/82/16060228_large.jpg
2- Raise a hood- With hood raised, hot air from engine bay can ventilate from the gap of the hood and wiper cover.
http://www.zerotohundred.com/newforums/members/d7zul-albums-my-new-ke70-picture7747-dsc00579.jpg
http://www.zerotohundred.com/newforums/members/d7zul-albums-my-new-ke70-picture7751-dsc00563.jpg
3- Remove the wiper cover rubber as in the redline in the picture. It will make better air ventilation.
attachment.php
4- Cold Air Intake CAI. With CAI, the temp during cruising at 3 pm is 34.5 deg celcius. (Measured at outlet of the CAI hose).
25191d1112767711-improvements-m116-early-107-true-cold-air-intake-w107-cold-air-hose-installed.jpg
by removing the wiper cover rubber, wont water or rain seep into the engine bay?
The rubber is higher up, water will drain into wiper motor area. Maybe some water will still splash into engine bay, but more actually comes in from the front and from underneath and most splash up by the belting....
You are correct bro. Thanks for explaining it. BTW, here is the picture vaporized wind screen when hot air blowing out from engine bay during raining.
attachment.php
I also removed mine.. as raised hoods sometimes poses a danger whereby if the mechanic or other ppl is not careful when they are raising your hood, it might break your windscreen.. or sometimes you yourself when you are in emergency cases and you forgot... the tip of the hood will hit the windscreen then = hailat.com :biggrin:
attachment.php
thanks for sharing.
may i ask about the thermal wrap..
I'm referring to the titanium wrap whereby it can withstand higher temperature..
the cons of wrapping the thermal wrap is that it become moist and will cause rust. normally people will do ceramic coating/power coating/ high temp paint to protect it..
which is not a cheap thing..
i actually had an idea, not sure if workable..
after wrap, spray with silicon spray. silicon spray is often use in auto bay to protect rubber and less friction etc, most important.. its waterproof..
i read that people in states are doing that..
hence, out of curiosity, i also intend to do the same and give it a try..
not really hunger for extra hp/performance but rather in maintaining the car..
any comments? :driver:
The silicone spray can withstand high temperature?
Yeah, silicon spray is commonly used in workshop by mechanics, it acts as a coating only.
Basically, to protect the surface from oil, water, dirt etc.m..
The prevention of the heat is lies with the wrap primarily
Is it silicon spray is same like wd-40?
Actually I've sprayed with high temperature exhaust paint before wrap it.
Sent from my Galaxy Nexus
me2kimi - I'm about to start on the header wrap like yours. How many clamps did you end up using? And where did you buy yours?
Sorry bro, I've forgot how many clamps that used. If not mistaken 4 clamps on the top, 2 clamps at the bottom. You can use drive shaft boot clip, but I used a hoce clip, the one like water hose clip. Easy to fastern and hard to loose.
Yup, trying to find out what silicone spray too. If those lubricating silicone spray, I don't think it can stand exhaust pipe temperature and will just vaporized....
---------- Post added at 08:17 AM ---------- 6 hour anti-bump limit - Previous post was at 08:16 AM ----------
When doing it?:driver:
good point stated there, so far, i can't find any articles that say silicon spray will vaporized..
but it definitely worth a thinker..
on what is a silicon spray:
Silicone spray is an effective lubricant on most surfaces and is noncorrosive or nonreactive. When sprayed on hard surfaces, silicone spray is able to maintain its lubricating properties in a variety of temperature ranges and environments. Silicone will not oxidize.
Silicone spray is resistant to water so it can be used to protect items from moisture. Boat owners use silicone spray on exposed boat metals to help inhibit the development of rust. If sprayed on material, silicone spray will soak into the material and help water bead up and roll off the material.
Due to the moisturizing property of silicone spray, it can help prevent rubber from cracking. If applied to rubber gaskets or other rubber items that may become dried, the rubber will be sealed. A sealed rubber gasket won’t leak moisture and become dried out.
It is easy to apply the lubricating and waterproofing qualities of silicone spray to difficult spaces. Rusted locks can be treated by spraying into the keyhole of the lock. The rollers of bay doors can be lubricated with silicone spray instead of an oil or grease that could ooze out of the track.
Read more: What Is Silicone Spray? | eHow
i also intend to do, going to workshop this saturday to change muffler then ask about the service.
could you share more about high temperature paint? how to identify
