6a12tt-rs.perdana v6
i was using original ssqv 1 but no sound as well only normal bov sound, when change to made in taiwan ssqv2 then only got kachinng sound
How bout blitz supersound bov.....it suitable for twin turbo?
Sent from my GT-N7100 using Tapatalk 2
---------- Post added at 08:26 AM ---------- 6 hour anti-bump limit - Previous post was at 08:23 AM ----------
Danz....how long u using ssqv2 made in taiwan? I heard from my fren he said taiwan bov very easy broke it is true?
Really needs helps....what BOV are suitable for twinturbo.....cozz im using sheep dog its Not make a terkukur sound.....im using this filter......
depends on your boost.
if u still boosting low, say under 0.8bar, then no use using sheepdog.
coz the tekukur sound can only get with high boost.
i've been using cap ayam HKS SSQV3 for 3 years no problem, but i only boost to 0.5bar la.
i see that u are already using openpod air filter..
same like mine..
i used for more than 3 yrs still working well when i sold the car.
blitz BOV produce my fav sound.
HKS like vry common. im in the midst of selling the car so no change BOV
but blitz is using piston instead of spring like SSQV,
hence it sometimes get jammed, ive experienced it, thats the downfall of blitz bov.
yeah i've heard the associated prob with blitz. my friend use it with some wd40. have not heard him complain for few years. not sure his luck or wd40 get into the correct place lolz.
yes budakkampung thats exactly the same BOV my friend used and the 1 i like.
Hahahah...already install blow off hks sqv and boost meter...
Guys wich area can get intercooler hose?like this 1 hose
aiya.. go make stainless steel piping la and add samco hose. :biggrin:
Heheheheh.....budged already lariii laaa....
What is difrent 0 bar and -0.5 bar reading at boost meter?wich 1 is true 0 bar or -0.5 bar?
Right or not this boost meter reading?
Siri bercakap dengan HP sendiri...
lol your IC piping look very raw and hardcore. hahahaha.
and boost manyak tinggi oo. all the negative reading is the vacuum pressure., before u hit 0.1 bar, means no boost kick in or vtec kick in yo! hahahaha
yes i think you have leak. usual reading is how much? also when the car is idling, what is the reading?normal i rmbr around -0.6 or -0.7
Normal idling rpm....
But my pomen said there no leak....when he test my car he said can go more then 1.5 bar....
