Hi guys,
I would like to call for a TTT April 18th 9PM USJ9 Arifin Maju. Welcome everyone.
THANKS chinozie https://maps.google.com/maps/place?...=en&ftid=0x31cc4cce3589a07f:0x3a7dad82f04421d
Thanks SHAMBURKE No. 9A, Jalan USJ 9/3F UEP Subang Jaya 47620 Subang Jaya Selangor MALAYSIA
Thanks Levin818 autosubmit (waiting)
Last event was disastrous, mainly of last minute decision of everything, so sorry. So this time, date, time, venue is clear and concise. Sorry that the only FRIDAY night available is 18th because I am currently working and living in HK, am on home visit to see my mom recovering well from a injured from a fall. My landing is 12th till 26th only.
And to make this TTT exciting, I am in need of advice for a PROJECT, hence hope more sifus sifus can come share your experience: -
As with every good Project Management (TIME, COST, QUALITY, OBJECTIVE)
OK, welcome everyone to join :)
- Priority target is 6 speed.
- Most notably I want the fullset ABS brakes.
- hence Altezza transplant into KE70 4 doors sedan.
- Including everything engine, rear axle, fullset Altezza suspension hence power steering.
- Hence also able to enjoy modern 17" rims without headache where to find bigger rims for the old 114.3 four lugs with rearwheel off-set no longer available.
- AIRBAGsss also.
- fullset wiring, ECUssss, fusebox, all wires for headlights, taillights, door mirrors etc.
- Altezza dashboard (cut cut) & aircond systems also.
- Lowered engine crossmember 2 inches or more. how much more ????
- Cut short propeller shaft. Push in engine, knock & cut firewall. Reduce CG like new 86.
- After complete send to chassis pulling & straigthening (who does this as business for a living??? need recommendation).
- Then send to SAND blasting (is Ramesh of CADBiz Sdn Bhd still doing this???)
- Finally spray paint. Simple metalic skyblue or white or silver. No dark color, Malaysia HOT.
- Objective is written above.
- Time (hopefully transplant in a week, chassis pull in a week, sand blast a week, finally paint a week), but we all know. But we must set target and not say I have time, then it would be worst. Right?
- Quality Altezza halfcut checking engine start, suspension, ABS, whatlot no leaks, no wire burnt. Chassis pulling means alignment results in both left & right have & achieve same camber, and more importantly CASTER, all four wheels are in perfect RECTANGULAR with crossing perfectly aligned. Not to mention all four top struts also rectangular and crossing centered.
- Cost, finally Altezza halfcut + rear pieces unknown, need quotation from fellow suppliers, email fcchin@hotmail, whatsapp at +852_91872761, thanks. Chassis straightening hopefully get quote from someone or recommendation? sand blasting by Ramesh $3.5k any other alternatives? finally paint I think we all know lah.
