Tire Price list Zth
I was asked by foreman to do alignment when he my servicing, so i assumed balancing is still ok..
Or should i have do it together?
I did alignment + balancing RM38-RM40
But I was once conned RM45 per camber screw if I recall correctly. :banghead::banghead::banghead:
So RM50 should be okay I guess.
Going to hup shun best talk to the boss himself which is Ivan. Don't ask the mechs anything. Just refer to the boss on price, if okay then the mechs will get the job done. U ask the mechs, I can tell u that the price they quote is big diff
I know the Boss name is Ah Tee (his surname), then an Owen but he is from Hup Shun SS3 but have since left....:driver:
---------- Post added at 04:05 PM ---------- 6 hour anti-bump limit - Previous post was at 04:03 PM ----------
Taiko,
I was recently charged RM50 for alignment + one chamber nut replacement. Is this price ok?
About that price for alignment and one pc camber nut including adjustment.
---------- Post added at 04:06 PM ---------- 6 hour anti-bump limit - Previous post was at 04:05 PM ----------
No balancing? :stoned:
No vibration no need balancing loh.....:smokin:
---------- Post added at 04:07 PM ---------- 6 hour anti-bump limit - Previous post was at 04:06 PM ----------
Camber adjustment can cost RM25 to 30 each, that is you have the camber nut already....:smokin:
Ya RM25 for adjustment and to swap to camber screw is RM45 a piece.
Dear all,
I am looking for GY Eagle F1 Asy 2 (Made in Germany), spec 225/45/R17. It would be great if anyone here can update on the current price.
Thanks ZTH.
Federal AZ01. Does not look appetizing at all. Small thin threads.
Feel like if I whack one corner, all the center is gonna rip off.
http://www.federaltire.com/en/images/products/b_photo_1353662627760.jpg
That is because AZ-01 is under Federal HP range only. They are called the Formoza range. If you look at the older pattern the Formoza FD2 lagi not sedap.....hahhahhahaha:rofl:
Federal at least must use UHP range. That is the 595 range, from 595, 595Evo, 595RPM and Extreme 595RS-R...:driver:
Heard some not-so good things about the 595Evo though. :smokin:
Hey guys if I dont wanna go for semi slicks. But I want the best dry grip and average wet grip
Besides RE002 what else is there ?
How about comparing it with Goodyear eagle f1 d5
Goodyear Asymmetric 2, PS3...as previous posts mentioned.
Asy 2 no 15" woh!
---------- Post added at 01:56 PM ---------- 6 hour anti-bump limit - Previous post was at 01:53 PM ----------
Below semi slick, have extreme tyres. Cheaper ones are Nankang NS-2R and Achilles 123. Then Kumho KU-36, GT Radial SX2, then Federal RS-R and Yoko Adavn AD-08R
Asy 2 no 15" woh!
KU-36 considered as Extreme? I thought it's UHP only. :slug:
Sorry I wasn't clear. I meant 15" only though and it must not be semi slicks :)
Haha if UHP non semi best is it re002
Can anyone have the latest pricing for the tyre size
225/45 R17 ?
currently using Turanza ER300 on my VW Golf.
I wan to change the tyre's - have anyone have the size tyre in new condition or know where to get better price with same range spec ???
URGENT-ly need help from all bro's from here
Thanks in advance ya
