tangtang22
Taiko,
I was recently charged RM50 for alignment + one chamber nut replacement. Is this price ok?
Taiko,
No balancing? :stoned:
I was asked by foreman to do alignment when he my servicing, so i assumed balancing is still ok..
Or should i have do it together?
Going to hup shun best talk to the boss himself which is Ivan. Don't ask the mechs anything. Just refer to the boss on price, if okay then the mechs will get the job done. U ask the mechs, I can tell u that the price they quote is big diff
Taiko,
I did alignment + balancing RM38-RM40
But I was once conned RM45 per camber screw if I recall correctly.
So RM50 should be okay I guess.
I know the Boss name is Ah Tee (his surname), then an Owen but he is from Hup Shun SS3 but have since left....
About that price for alignment and one pc camber nut including adjustment.
No vibration no need balancing loh.....
Camber adjustment can cost RM25 to 30 each, that is you have the camber nut already....![]()
Federal AZ01. Does not look appetizing at all. Small thin threads.
Feel like if I whack one corner, all the center is gonna rip off.
http://www.federaltire.com/en/images/products/b_photo_1353662627760.jpg
That is because AZ-01 is under Federal HP range only. They are called the Formoza range. If you look at the older pattern the Formoza FD2 lagi not sedap.....hahhahhahaha
Federal at least must use UHP range. That is the 595 range, from 595, 595Evo, 595RPM and Extreme 595RS-R...![]()
Hey guys if I dont wanna go for semi slicks. But I want the best dry grip and average wet grip
Besides RE002 what else is there ?
How about comparing it with Goodyear eagle f1 d5
Goodyear Asymmetric 2, PS3...as previous posts mentioned.
Asy 2 no 15" woh!
---------- Post added at 01:56 PM ---------- 6 hour anti-bump limit - Previous post was at 01:53 PM ----------
Below semi slick, have extreme tyres. Cheaper ones are Nankang NS-2R and Achilles 123. Then Kumho KU-36, GT Radial SX2, then Federal RS-R and Yoko Adavn AD-08R
KU-36 considered as Extreme? I thought it's UHP only. :slug:
Im on 15s too. Also, everything we mentioned are not semi slicks. Heh.Sorry I wasn't clear. I meant 15" only though and it must not be semi slicks :)
Haha if UHP non semi best is it re002
