go for evo3 vented hood.
The starting self-check light is working and I have just serviced the brake including the pistons 2 months ago in August before the incident so I suppose the pistons aren't giving problem. The only plausible explanation as you said is ABS is out as I couldn't feel the pulse.
As a side note, my brake vibrates even after doing rotor skimming and it pulled side way during hard braking. I have got all worn out suspension arms fixed but the problem (the vibration and side way)still exist.:hmmmm2: It's weird.
Vibrate when hard braking?
Usually pull one side means one side brakes biting better then the other side, not balanced....:rolleyes:
---------- Post added at 04:11 PM ---------- 6 hour anti-bump limit - Previous post was at 04:10 PM ----------
Evo 3 vents are in the right areas? Evo 3 is straight 4 and Perdana is V6
last time I used evo3 mated with v6 hood onto my perdana, so far ok, no issues.
My bumber slightly drop on the left side but its being year. Later will replace new one and whole body painting. Perdana have such issue due to its very low. Once you hit something than it will slight out of position.
I spend ard 7.5k for engine + wiring. Budget your self ard 10k.
I change 17" rim, tyres, engine, front lamp, steal piping, boost meter, turbo timer, speed cut(reach 240kmh) + accessories already 16k.
Still many to do but it will blow you mind away with turbo engine. Just a bit costly on the fuel, long distance v6 clock at 580km and with turbo ard 380-420km.
I still learning everyday abt the engine. The more u learn, the more u understand, the more u spend, hihi..
That is super high FC for highway, even for a turbo isn't it?
Just surveying perdana v6 price today and price has dropped so tremendously since I got my car a year ago. A 2010 Perdana is cheaper that what I paid for a 2005 Perdana. *sigh*
