Seg ae101 digital a/c button blinking?????
Din't know compressor that hot. Did you test pour water on other car compressor? It can be both compressor faulty since halfcut condition. Any chance to test on recon unit?
i got the same problem like bro maxtrust.
ae101 bt digital a/c. after car warm up, ac auto cut off and on back after some time repeatly. no matter in jam or running on highway day or night.
check with a/c machanic he try to direct power to compressor also wont engage. sensor checked working fine. he suggest to replace the clutch for the compressor.. hvnt have the time to do yet..
but in the other hand my car got issue at the
1) a/c panal, the blow/vent direction button light will only on when press harder and if release then lights gone. and because its a 101 dashboard. A/C button no problem.
2) a/c temperature malfunction as moving left and right/ hot and cold will affact the blower speed.
3) aircond pipe HOT side no valve to check pressure as its a custom pipe.
its a used car i just bought and i doubt the ex owner never did the transplant job nicely as the wiring in the car is so lausy just to look at it... its a ae 92 running on bt 6 spd with a 101 dashboard.
hope expert or anyone face this prob before can give any idea about it...
This guy resolved my previous SVT A/C problem that annoying me for more than 2 years.
He deliver great job at a reasonable price. Highly recommended!
Chua Car Care / Alpha Car Cooler Services Centre
No.11, Jalan USJ 1/20, Subang Jaya, PJ
Contact: 019-220 9942 (Paul Chua)
hon_cs
ya test on same bt 20v n sv 20v no boiling, going to try recon unit today.
Levin818
thanks will try to arrange if i have the time.
hon_cs
Levin818
Should not be boiling, if boiling something is wrong dy.
The air con mechanic do not know what is wrong?:hmmmm:
there is an aircond specialist "Ah Hoo Car Air Cond" just a couple of shops near to Daz Garage @ PJS 1.
Sounds like electrical control unit malfunction rather than mechanical.
Try swap in another A/C control module. It is located somewhere near to the blower fan.
Levin818
Ya only AC control module haven change i suspect it also but my forman currently don't have the same model.
He told me got 3 different type, the 1 he has not same model tested the ac does not cut at all but compressor super boiling.
last few days has change alot of things to troubleshoot but still haven found the dam culprit.
Item change to troubleshoot last few days.
2 unit compressor chop shot
2 unit direct take from halfcut out
2 valve
change new condenser
Total item change for troubleshoot till now 5 compressor 3 condenser 2 filter/dryer 3 valve. ??gas refill
consult 3 different AC shop all say compressor 1 say he has this issue b4 after change 4 compressor still no successful the last he change a new condenser thats y we bought a new 1 to test.
some other ac shop say they dont 1 2 touch 20v ac coz alot issue :stupid:
Going to get my car back today coz going back home town this weekend, will only do after CNY.
Usually condenser seldom give problems. Mostly is Compressor, Receiver dryer, expansion valve and lastly the cooling coil. In fact, recently my VR had some issues too, needing to top up gas every 3 months. Since mine is running on the old freon gas system, one air con mechanic change one of the hose and receiver dryer, vacuum and recharged but only lasted 6 months. Went back to my usual mechanic who does my servicing but do air con too, he suspect the condenser. Took out but cannot find replacement as car very old and running old gas system, so he pump petrol in and clean. Vacuum and recharge and now lasted more then a year, so touch wood it remains like that.....:biggrin:
Ya i know change to new 1 coz no others thing that can be resolve so 1 of the ac shop guy say he has encounter B4.
also new 1 cannot be refund, the use parts or halfcut unit my foreman can refund it.
The problem is your A/C compressor reaching higher temp than normal before it get cut off. And because of that, the compressor require longer time to cool down to reach triggering temp.
IMO there is a temp sensor that attach at the compressor responsible to deliver temp signal to the A/C control module. The module will turn off the compressor when the compressor's temp hit the upper limit, and turn on the compressor when the temp hit the lower limit.
Since you have replaced 5 compressor and the problem still remain, the culprit should be from the A/C Control Module.
You either have a wrong module, or your module is faulty.
Bro. levin, the compressor cut off not by air con cooling coil thermostat? When reach temperature set it cut the compressor from cooling further and switches it back on when temperature goes back up.
Levin818
Ya only left with the ac control unit dint change, coz have mention before the correct model my forman don't have.
As he mention he only have the levin type model my should be wagon type which is the show in pic.
1 of the ac guy ask to modify the original thermostat to others to let it cut more often so that the compressor won't over heat but i dont want them to mess-up my original wiring.
Yes cooling coil thermostat is when the temp reach the coolness it will cut a wile.
At the top of the compressor is monitor the compressor overheat,is like the fail safe switch.
Levin818
You mention that the ac shop fix ur acc issue, can i know what u facing previously? and what did he change to solve it?
Yes the compressor also cut off by cooling coil thermostat, that is when the cabin temp has reach the preset level.
The A/C control module turn off the compressor when the compressor's body temp is too hot. This is so call over heat protection.
---------- Post added at 02:13 AM ---------- 6 hour anti-bump limit - Previous post was at 01:15 AM ----------
Levin818
My previous SVT has aircon gas leaking problem. The R12 gas will gone in within 2 months after refill. And for 20V rotary compressor, if your are running it with low pressure of gas, the rotary blade will worn out and start to give krek krek sound which is irreversable. I have lost 2 compressor because of this leaking problem. My car has been in out many times at my prev aircon guy's workshop, but yet the problem still will come back 2 months later. I even request him to replaced all the O ring but problem still remain.
After that i get refer to Chua by Goodspeed Ah Choy. Chua is actually handle all aircon work for 20V that transplanted at Goodspeed. To my surprise, in just within an hour Chua managed to detect a minor gas leakage at one aircon piping's join. When open up the join he found that my prev aircon guy has gave me a wrong thickness of O ring, an O ring that not for aircon application...
Here are work done at Chua's workshop (those that i still remember):
1) strip down all aircon piping and replace all O ring
2) service the cooling coil + compression test
3) Plug in BT compressor (SVT's have krek krek noise already), and coupling it to existing R12 piping with a R13a-R12 adapter
4) R12 gas refill
After that, the problem never come back
4) R12 gas refill
Oh! did not know there is a control fail safe on the compressor overheating also...:rolleyes:
On your second part, running on low gas pressure, mine have a sensor at the receiver dryer and when on low gas it cuts the compressor from running....:driver:
