0.5v is ok then right?
Should i need to calibrate again?
If you still having the jerking, try calibrate again to different setting then try again...I think you need to trial and error also....
i have check the voltage for the tps,
throttle close-0.5v, throttle open-4.9+v
is it ok?
should be ok....or try slightly lower max value around 4.7v
If i lower the max value, the throttle closed value will reduce right?
coasting setting? but ecu is stock right?
hmmm, what cause engine braking...too much...
Since you are still having the problem, no harm trying or testing different settings....![]()
adjusted to 0.4v when closed
same also..sigh~
or worst case...ecu internal capacitor leaks....
but there is plenty of ecu guys can do replacement on that capacitor....
Technician also can fix if really capacitor problem. Take out and replace with same unit....![]()
for hardcore DIY fan sure can![]()
