guys,any good foreman to recommend to me for a good engine tune-up?....pls yeah,if u do have on mind ...thnx!
CARENT said:Hi bro,
Wht sort of tuning are u looking at?
My foreman is very good in mechanical tuning including setting of the adjustable cam pulley... :)
He is located at Puchong / Bandar Kinrara. price reasonable as well.
Cheers...
dolly said:satria81, that would be your base ignition timing advance. best you dont mess with it and leave it at the manufacturer specs. Your ecu will base its timing off this, so for every degree you increase, you increase it across the whole rpm/load range.
yes you can gain power and fuel economy when cruising but you also risk running into detonation
johnchow73 said:Dear friend, first of all, for NA cars you can spend thousands and you can only get about 30-50hp extra. But if you charged up your engine you gain from 75 to double or triple or even more HP than stock.
Please consider this first. ( From my experience )
If you insist on NA. OK.
First your budget. ( How much u want to spend?)
Second, how you want to drive your car? ( Street & Strip, Drag or race )
Johnchow73.
deacon said:I think that turbocharging is ok, but it always makes me feel that more is better and sometimes that isn't very cheap route to pursue. I would prefer some form of variable timing engine building parts at least you still get the kick. My 2 cents :P
johnchow73 said:Satria 81,
Here are some tips you can do to your engine.
1) Change to aluminium adjustable cam pulleys.
2) Change to light weight crankpulley.
3) Skim off about 1kg from your flywheel.
4) Change to an adjustable fuel regulator.
5) Add a piggy back CPU ( Greddy E'Manage )
If tuned properly, you will get an extra 15-25hp.
These will cost you about RM 2500.
johnchow73 said:Dear Potssum, you'll get a lighter feel in the upper RPM range, something like kicking your girlfriend out of the car.
