You buy engine time did not check the engine out? And are you sure is head gasket leaking or maybe valve cover or something else? What I mean is since budget restricted make sure you are repairing things that needs repair.....
You buy engine time did not check the engine out? And are you sure is head gasket leaking or maybe valve cover or something else? What I mean is since budget restricted make sure you are repairing things that needs repair.....![]()
After installation, i did test it out. The gearbox felt smooth at that time, no white smoke coming out, aircond super cold, crank once without stepping on gas engine straight away fired up.
Wah! 4G93 SOHC already RM6k, anyway for your gb your mechanic cannot check?
My mechanic friend can't check the gearbox. I went to Win Tech Auto at Subang Hi-Tech just now. After diagnose and computer check, workshop said clutch burned (weird funky smell from ATF oil). Pressure not stable hence the lag and jerking. Overhaul and replace all oil seals and gasket. Total RM1.5k inc. GST. Friday or Saturday can pickup the car.RM6k include transplant.My mechanic friend can't check the gearbox. I went to Win Tech Auto at Subang Hi-Tech just now. After diagnose and computer check, workshop said clutch burned (weird funky smell from ATF oil). Pressure not stable hence the lag and jerking. Overhaul and replace all oil seals and gasket. Total RM1.5k inc. GST. Friday or Saturday can pickup the car.
Include transplant then not too bad. Workmanship can come to 1k plus.
Try fitting atf cooler after repair, and/or dump is a bottle of Lubegard atf additive
Alrighty. Will check with the shop when it's done. Hopefully no more problems in the near future. haha!
UPDATE: After changing the ISC and fuel filter, no more serious idling problem except while aircond compressor is on, timing went up a bit. No more serious 'semput'-ness but engine still idle a bit low (600-700rpm) when gear is in D and aircond is on. Gearbox gradually feeling a bit better but I still feel I need to send it for check up.
Gonna send it for top overhaul next month. Any tips on that? :)
When you are in gear, the idle will drop a bit because you are causing load to the engine via the GB as well as the aircond compressor (double whammy). Not only that, when your radiator fan kicks in, it sips power as well causing load. Try raising your idle timing a little higher let's say 900rpm to 1000rpm on pure idle without the radiator fan kicking in, without air-cond turned on and not in gear.
Installed any grounding wires?
Aaahhh, getting a manual?![]()
Nope. Overhaul my auto gearbox. Just called the workshop. I can pickup my car this evening. Will update on the progress.![]()
Hopefully all is well this time :)
Just got back my car. So far all the semput-ness no more. It was the gearbox after all. There was heavy traffic from Subang Hi-tech heading to my place at Subang Bestari. Gearbox works smoothly running through the traffic jam. No more jerking or timing drop like crazy.
I then get to test the shifting at Guthrie highway. Car was on Eco mode and managed to hit 140km/h effortlessly. There's some knocking sound at high RPM (6500). Maybe need to go adjust the tappets coz it's a bit loud.
Any workshop should be able to do the adjustment right?
Yea any workshop can do but best to go back to your trusted mechanic if you have one. When you changed your ISC, was the current one already bad condition to begin with?
Rebuild woh! means repair his auto gb......lol![]()
The ISC looks pretty bad. No choke during cold start. Now way better and after gearbox repair, timing is a lot smoother. I set the idling to 1100rpm when aircond is on. Gonna go and adjust the tappet and knocking next week. So far, I'm very satisfied with the car after the gearbox repair.![]()
That's good news indeed. After readjusting the tappets, then can say your car's problems are fixed![]()
with the use of ficd, u need to disable the original ISC....
im using 2 ficd...1 for cold start and another one for ac.....because my car isc went crazy idiotic setting....now worn gear..no check engine light, tps voltage setting was correct....but acting weird when morning cold start works fine...then alter 20mins trip or 30mins trip..stopping at traffic light, the idle speed will increase to above 1200rpm.... sometimes ok..sometimes not....so i locked the isc to predetermined setting, remove the gear linking isc to the stepper motor...then put 2 ficd..problem solved...now i got manual cold start choke and ac idle speed control..which both i can manually fine tune with just screwdriver![]()
(*i'm a manual man)
