drummydrew
All. Does it gets louder when you drive or just when idling? Mine had that before. Just weird noise when idle due to the tensioner pulley bearing worn out.
yes the sound does get louder as i accelerate, ok i'll be sure to get all of the pulleys checked out when i visit the workshop this week.
every time i do something new for the car, it returns me with new noises, unpleasant ones
along with that just to share a quick one on my ANOTHER existing probem:
been having issue with the AC on both idling and driving, RPM tends to fall short by 300-400 whenever AC is on. troubleshooted with a new stepper motor but problem persists, mechanic confirmed that signals from ECU socket seem to be working fine so it is now either:
1. my previous mechanic (the same one who slit my throat) may have replaced my faulty AC compressor (15C) with a 17C one which is for higher displacement, causing it to run heavy.
2. Alternator. Will get the charge rating checked when i visit the AC guy on tuesday, hopefully that solves it once and for all
will be posting updates on both the AC/RPM and Modem-Dial-Up noise problem!
.. and then get him to listen to it
All the while from inside hear noise coming from driver side.....hhahahhaha
[/U...
