4G93 DOHC Problems
All. Does it gets louder when you drive or just when idling? Mine had that before. Just weird noise when idle due to the tensioner pulley bearing worn out.
yes the sound does get louder as i accelerate, ok i'll be sure to get all of the pulleys checked out when i visit the workshop this week.
every time i do something new for the car, it returns me with new noises, unpleasant ones :itsme:
along with that just to share a quick one on my ANOTHER existing probem:
been having issue with the AC on both idling and driving, RPM tends to fall short by 300-400 whenever AC is on. troubleshooted with a new stepper motor but problem persists, mechanic confirmed that signals from ECU socket seem to be working fine so it is now either:
1. my previous mechanic (the same one who slit my throat) may have replaced my faulty AC compressor (15C) with a 17C one which is for higher displacement, causing it to run heavy.
2. Alternator. Will get the charge rating checked when i visit the AC guy on tuesday, hopefully that solves it once and for all :adore:
will be posting updates on both the AC/RPM and Modem-Dial-Up noise problem! :driver:
Your ecu is working of course, giving signal to stepper motor to adjust idling.
Sometimes i confused. As read through googling.
Some say ecu wont know isc/stepper motor position. Fair enough.
But then the scantools can set isc to middle position. Dang....
At the end i use hand to set isc. :stupid:
that is one confusion stirred up right there :hmmmm:
i set the isc by a screwdriver too, told to do it only when the fan is running for better accuracy. any comment?
that one you set by hand is BISS screw.
isc can only set by scantools.
http://www.3si.org/wiki/index.php?title=Idle_Problems&redirect=no
some idea about idling.
Oh! if all okay and battery goes dead after a few days, check for parasitic current draw also
Happened to me recently. If left for few days, battery gets drained. Finally tracked it down to the rear trunk lamp not getting switched off after trunk lid is closed.
If it's a bearing issue, the mechanic should have a stethoscope thingie to check the vibrations from bearing housing.
thank you! i understand it better now. how i see it now, i can't see any wires leading from both the AC compressor and PS pump to the ECU socket at the firewall so the ECU is technically not processing anything to the stepper motor (aka ISC?) when the compressor and pump are on load. my fitted stepper motor and the old one seem to be fine as RPM raises then slowly falls back during start up.
how do you suggest i go from here? proceed by checking the alternator's and compressor spec, or scantool it? :itsme:
recently replaced a battery which didn't last a year, after i left my car unused for few days too! couldn't even jump start it :stupid: i NEED to resolve this issue before i waste another new battery! will begin by checking the alternator's charge as advised by bro vr2turbo, step by step i'm pacing very carefully this time. :secruity:
i really hope workshops are this canggih but sadly i haven't seen any mech who uses a stethoscope alike tool for diagnosis. of cos, this is only my world i'm referring to :wavey:
It's a simple but effective tool. Seen my mechanic use it
http://img.directindustry.com/images_di/photo-mg/169-2614429.jpg
Just a stethoscope with a prod attached. Shouldnt be expensive
this shall be an automobile quote! i suppose noises are good for indicating problems, but meddling in it continuously can get sho frustrating..
Catching where the sound comes from can be very tedious. I had a fair share of it....:banghead:
Yup, must have sensitive ears and inquisitive mind. Doesn't help if the vehicle rattles a lot OR if you have loud exhaust OR power amps. LOL .. my mechanic's ears are quite deaf.
@drummydrew, you should buy Uncle VR a ::tee: .. and then get him to listen to it
perhaps you can show me some pointers on tracing noises? hehe
precisely, my loud exhaust surely doesn't help when trying to listen out. yes i was wondering on that, yall sifus meet up for drinks for crazy car talks? i wanna join! :biggrin:
About compressor, my 93t will give a (one second) "mouse" squeek sound when it kick in + i step on throttle.
Idle no squeek sound when it kick in. Any idea sifu ? Belting ?
Feel kind of heavy too.
Every noise/sound to trace are different. Need at least 2 if not 3 to trace, especially when need to drive to find the source. Like one of my problem, sound comes only when hot. Cold time no sound. Sound can be hear coming from driver side lower arm. Check for a long time, then one day ran until hot the sound came, straight drive to mechanic ask him check immediately. Jack up car using car lift still cannot find, then place on those 4 pole car lift where you need to drive on type. Raise up then violently try to shake car up and down. Hear the noise then trace, and finally found it coming from passenger side steering arm....:hmmmm::confused: All the while from inside hear noise coming from driver side.....hhahahhaha
The steering arm dried up and squeak when hot, after change no more sound......lol:biggrin:
UPDATES on Modem Dial Up Noise: good afternoon all, i was at the workshop just now tracing the noise with my mechanic. instead of a stethoscope, we used a long screwdriver and pointed it on the pulleys' area then listen from the other end, works the same! first replaced the tensioner/idle pulley's bearing because we traced a winding noise on it compared to other pulleys. got back into the car and the modem noise is still existent probably louder this time :confused:
then i got curious and decided to work that stethoscopic screwdriver on the newly installed FPR, and jackpot i found it! the dial up tone is from the FPR bolted on the firewall :smokin:
this incident reminds me of a similar noise after i replaced the fuel pump last year, its still audible but i have come to live with it already. now a new noise which is fuel related.. i'm not ready for a new noise! anyone has any experience on this? :bebored:
Bro, sorry for asking but why need to use adjustable FPR? Doesn't the stock unit fulfill your needs? Do you have large cams installed or have you upgraded to larger injectors?
Mine got that whiny noise after start the engine only. then it gets quite when the vacuum is ok. Weird that yours got sound while engine is running. Maybe you should check all hose for vacuum leaks.
no worries bro, previously i thought the same as you but the problem is i couldn't source any stock regulator from the spare part shops i know of, which include an authorized proton dealer. that led me to 2 choices, either a used one from chop shop or, a new FPR by a trusted brand. i went for the latter, cams and injectors are stock. reason why it was already fitted with FPR is cos the previous car owner ran this on a piggyback so he had some extra toys thrown on. hope that answers your question. :shakehands:
i checked on the vacuum hose, trimmed and fitted it nicely back unto the FPR, set the bar at 3.2 and BISS screw idling slightly under rpm1000 with AC off. the noise got softer but still audible even when engine is running.
hmmm.. got any photo of the FPR ah?
