Note sure about the better flow part but mine isn't cast iron. This is what the original looks like.
That's the hotbits one or what?
I had the Hotbit's header destroyed to prevent resale to unsuspecting buyers.
The one in the pic is the original Proton header for Wira 1.8 DOHC
Does your car have a 02 sensor? There's no port for the sensor on this header set
Mine was the original batch of C99 limited edition. No 02 sensor because it was never meant to be environment friendly. Not meant for export. Later models came with catalytic converters and 02 sensors.Mine got. Maybe coz it's a single cam auto? That's the mivec cast iron headers
Here's a pic of the header I replaced recently. Since my car doesn't have a 02 sensor, they welded the port shut.
Paid 250 for it. How much did it cost you, RENESIS?
The Hotbit's unit was 1-piece. Had difficulty removing it. I asked them to cut it into 2. This is also to prevent the old header from being re-patched and later re-sold.
@RENESIS, the original header also not stainless steel. Used for 20 years. No leaks or cracks
Your engine bay has a lots of space between the header and the radiator fan. Can put one of those fancy extractors with long runners. Mine doesnt have such space
That actually happened once before. Melted one of the plastic legs off the bracket.Are you worried about the heat from your header damaging your fan?
It was a one-off incident. Was caught in moderate jam at Pudu. Suddenly temperature shot up. Found a place to park and opened the bonnet. Top legs was detached from the main frame and the fan assembly fell over & was resting against the headers. Luckily there was a spare parts shop nearby. Walked over and bought a standard proton unit. Been many years since that and the replacement fan hasn't failed yet.
For an NA engine, there hasn't been a need to upgrade radiator/fan assembly. 4G93 DOHC heats up from cold start really fast. I believe this engine builds up heat easily but using Toyota coolant, engine temperature has been stable even when revved hard up Genting. Thus far, I only had radiator top panel replaced once. I believe turbo units may require better cooling.
Edit: Sanekit appears to have red colored aftermarket radiator. Looks slimmer compared to mine.
Edit2 Oops. The red color is not a radiator :stupid:
It was a standard proton fan. Came with the car when it was new. Don't think I can blame it on the heat of the header. The replacement fan has been in use for years without issues. Tbh, I cannot tell how the legs broke off. By the time I opened the bonnet, it was melting against the headers. Hard to pry it out since it was stuck.Is the melted fan a standard Proton unit or aftermarket? Is it because it melt due to top legs detached and the fan fell over? Or the heat broke the top legs?
Are you thinking of upgrading your fan?
I support that idea. If it aint broke, dont fix it.it is managing the temperature quite well even when I am driving at near 6000rpm in 4th gear, I don't plan to change it now.
LOL. Radiator is not there. I'm using double layer long radiator as my car is auto. My headers comes with the stock heat shield.
