auto forever.......![]()
fuhhh....nice
1000% look better than mine engine bay.![]()
nice clean engine.
you relocate your battery to the rear? will it prolong the battery lifespan?
the timing belt cover, is it transparent type? how long you been using it?
mine just crack on one of the holder, very noisy when the car moves .
You can try heat shield your battery. I did for my SUV seems to be longer lasting. Most of my battery last 18 to 26 months only, now on 39th month....![]()
very bling bling
Update on my TT
IINM, JPJ rule said that if u change gbox from Auto to Manual or Manual to Auto, it should be checked by the Kejuruteraan Automotif, JPJ for approval then inspection by Puspakom (but ppl dont follow this). for further info just call JPJ hotline, they are helpful.Lets say I get a manual gb for pv6...does it needs2b inspected by JPJ or Puspakom...as in our registration card....it stated auto.
Manual gb coms wt hydraulic pump on clutch so whn we press/step on d cluth,it dun feels heavy or tight?.....
Read tht manual gb market price now is RM3k++....non include labor yet...
Is thr any othr manual gb pv6 can fix ?....
i strongly advise to stick with SP3 formulation as its the requirement from Mitsu. or u can use Multi-Vehicle ATF that can cater for SP3 like Pennzoil Multi-Vehicle ATF (I'm using this for a long time now) or PetroCanada MV ATF.Hi guys
Can I use Toyota ATF type 4 gearbox oil even there is no sign of gearbox issues.?...
Or should I stick back to Proton/Diaqueen ATF SP III?....
nice clean engine.
how to heat shield battery?
do tell me more..
battery like that, can do heat shield?
my battery is about to change, now the whole car is in workshop for overhaul.
good time if I wanna modify anything.
my battery lifespan is always around 2 years, now is better with bosch battery, 26 months.
nice clean engine.
yup, put my battery in a box in the boot. i donno if taking it out of the engine bay to somewhere less heat will effect the battery lifespan.
i use NS70 size and it usually lasts me more than 2 years (Bosch S4 - 3 years, Century Ultramax 2.5 years, Yokohama Gold - still using, more than 1.5 years now)
the transparent timing belt cover just been using it for 1 year. the original one already crack teruk. this transparent one still no crack but got oil burn (that time got a bit of oil leak from the rocker cover).
Mine using simple aluminum foil only. My SUV battery is just behind radiator fan, and the hot air keep blasting on the battery. I took no notice before but after sending battery to spare part shop for claim, the personnel wanted to test the battery first, he touch the battery and say your battery so hot cannot even test. Left it there to cool down then after test they replace a battery FOC. That gave me an idea to heat shield this battery.....
Try to find and see if still have some photos...
Originally like this...
Radiator fan and battery
Heat shield
I did it, battery relocation. So far ok. Use good welding cable, pure copper prefer.
I'm also using NS70 but Bosch S3..
if I not wrong, the transparent cover will turn black over time due to heat.
is it ok if I don't put the cover?
it was there to protect the timing belt only.
i relocated my battery during the work in transplanting the turbo engine.ok, I ask the mechanic how much it cost..
hopefully not too expensive..
*ok.. my mechanic just told me not to waste money..
my engine bay still got room..
I always change battery like 2 years + which is consider very good for nowadays battery..
tell me not to spend money..![]()
haha, very cute.. why don't you relocate the battery then?
sorry, I feel with such insulation, it does not really help much..
for normal driver, just look for gbox F5M222 from Eterna or Galant. there are others that may fit like F5M312, W5M332, W5M312
hi mymax, where hv u been le?Hi guys.. such a long2 time not to communicate with the otais in here
IMHO, if the budget is there then just go for any gbox as mentioned by neuroone.. mine just use the basic F5M222, changed over the last 7 years and still running perfectly.. giving you peace of mind instead of auto tranny
