install Pivot Speedmeter or Apexi RSMHi Sifu sifu... need an advise
Currently using stock ecu with safc.. with stock ecu cms the prob of speed limit.. any idea what to do..
speed limit? wow.. what speed you are on..
another cheap way that I know, is to modify the chip in current ecu.
I saw a few that are doing this.
my current ecu also modified, no speed cut, launch at 4000rpm
2-step? tyre not spinning at 4k rpm?
what is 2 step?
initial, tyre do spin..
like fast & furious
but after time, you know how to control, is still ok.. just controlling of clutch, slowly release
perdana chassis is quite heavy, not easy to spin..
I'm also using Potenza 002, 225/45/17
your ecu is rechip or?
2-step is 2 different rev limiter, usuallly to build boost during launch.
i've seen perdana tyre spin through out 150-ish meter during drag day..even my manual last time spin out during launch.![]()
mine is a rechip, modify the main chip if I got it correct.
Anyway I don't drag or race.. so to me, its overkill..
I only got it because my older ecu is damage, cannot control the boost.
When I boost, my wife will scold me..
anyway my driving habit also gentle..
I slowly release while in 1.5 - 2k rpm..
family car..
safety come first..
where do you purchase your rechip? chop shop?
Looking for rechip to replace stock ecu..![]()
Not sure if this guy can solve your problem.
Anyway what is the top speed for evo engine?
me 180 only![]()
me 180 only![]()
I saw an add a guy Unchip and got lauch control for this V6TT... really got such thing? Any contact of the mechanic that modify ur ecu?
me 180 only![]()
HI kurt any contact no.. wanna make appointment
