Perdana V6 Community Forum *
Hi Sifu sifu... need an advise
Currently using stock ecu with safc.. with stock ecu cms the prob of speed limit.. any idea what to do..
speed limit? wow.. what speed you are on..
another cheap way that I know, is to modify the chip in current ecu.
I saw a few that are doing this.
my current ecu also modified, no speed cut, launch at 4000rpm
2-step? tyre not spinning at 4k rpm?
what is 2 step?
initial, tyre do spin.. :biggrin:
like fast & furious
but after time, you know how to control, is still ok.. just controlling of clutch, slowly release
perdana chassis is quite heavy, not easy to spin..
I'm also using Potenza 002, 225/45/17
what is 2 step?
like fast & furious
your ecu is rechip or?
2-step is 2 different rev limiter, usuallly to build boost during launch.
i've seen perdana tyre spin through out 150-ish meter during drag day..even my manual last time spin out during launch. :rofl:
mine is a rechip, modify the main chip if I got it correct.
Anyway I don't drag or race.. so to me, its overkill..
I only got it because my older ecu is damage, cannot control the boost.
When I boost, my wife will scold me..
anyway my driving habit also gentle..
I slowly release while in 1.5 - 2k rpm..
family car..
safety come first..
family car..
safety come first..
where do you purchase your rechip? chop shop?
Looking for rechip to replace stock ecu..:driver:
I got it from my mechanic, if I recall correctly, there's this guy who does such stuff in KL.
if you keen, I can pass you my mechanic number.
you contact him for more info as he's more familiar as compare to me
My friend gave me a unit called speed limit defencer, but in the end did not install it as seldom hit until that speed.....:driver:
Not sure if this guy can solve your problem.
Anyway what is the top speed for evo engine?
