Habis la...I stand far far away from Izso. Put signal tepi...
Not open vtec when he pass.......lol
Tq boss
BITD when I was into BMX bikes, we called this kind of welding pateri sisik. All the good bike frames had this kind of welding.where's shop that do the welding? damn nice.
Hoih, kuli sajer. So i assume the car now being work in a kickass garage somewhere?
It's in Ampang. The shop owner has his own drag EG there and his handiwork on his drag car is pretty impressive.
According to waze its : Workshop SPG @ Ajip 87
No 31 Jln Avenue 3, Ampang
4 inch..a kitten or mouse can easily got lost in there.
let me check my signal indicator if its still working...nedd to indicate left when see this car in my rear view mirror.
then lower the driver window to hear kecis sound as he pass by.
Reduced 20-30% overall noise. Hard to do when the whole exhaust setup is 4" front to back.
is his price affordable? :vroam:
Getting smaller siput still on 4"?
To custom weld and shave the turbo inlet / outlet ports, install, reduce downpipe size, injectors and install the muffler all in with custom welding and all RM750. It's quite ok considering the amount of work needed and all.
do you plan to put the birth of your new baby in RnR post?
wah.... including material? nice nice.
Cold start + warm idle + mild rev vid. This isn't too much to ask for i guess haha.
Bro Izso, what the expect hp with this downsize setup? How's the driver feel conti with 1jz?
The exact HP will be known after the retune. Driving a conti with a 1jz isn't new to me. It's quite exhilarating once the boost kicks in but the other contis I tested were autos. This will be a 5-speed manual 1jz. And this car has a bigger turbo and more aggressive setup. I'm salivating and counting down the days.
You should document this build bro, I'm considering similar build in the future but maybe in a bigger chassis
Can't wait till it's all done, should be putting down stupid amount of power + fun.
Technically it isn't a build. It's already built. I'm just refreshing it
cross breed of godzilla and jz engine
