Add a spacer. Maybe a thin one will doI have 1 set ori rpf1 15 inch et35 4 x 100 but cannot fit in my xp150 vios,the brake caliber just touch the wheel,any way to make it clear?can i sand my caliber to fit it?
Ori caliber,touch the wheel not spoke...no modified anything yet just want to put in the rim to look nicerHuh, ori RPF1 cannot clear the brake caliper? Is it stock calipers or already modified to bigger ones? How much is the touching and where is it touching, is it on the spokes or the wheel rim?
If want to clear it need to add like 20mm spacer like that,and the wheel will come out from fender leh...Add a spacer. Maybe a thin one will do
How come original caliper cannot fit 15" rims?Ori caliber,touch the wheel not spoke...no modified anything yet just want to put in the rim to look nicer
Ori caliber too big i thinkHow come original caliper cannot fit 15" rims?
vios has tiny calipers, rfp1's also have very flat spokes that dont curve in and the original rim offset is 45 kan?Ori caliber too big i think
But if original caliper cannot clear rim designer should be shot, how to sell........hhahhahahhahaRPF1s has a very small wheel barrel by design......not the first ive heard about clearance issues between the barrel and the caliper.
solution: change rim HAHAHAHAHAHA
Like that the copy not actual copy because different.........hhahahhahaha+35 offset is already plenty out....
u sure the wheel is ori rpf1?
i suspect it was some shit replica copy fake imitation
The offset of ori rim i dont knowvios has tiny calipers, rfp1's also have very flat spokes that dont curve in and the original rim offset is 45 kan?
dont see why it should hit the caliper....
eh cannot main change change like that without knowing the diferences between the rims you have and the rims you want to change toThe offset of ori rim i dont know
