Ah, I thought the CEL triggered a reset
The CEL only appears when the RPM stops working, like i said the issue can be resolved by simply restart the car. Of course i hope there is a remedy for it.
do you have any volt meter to monitor voltage issue to see if it related
to drop to 12v is kinda low. how's the grounding for your car?At times when my car's voltage drop by 12V, this will happen, however i can't find relation to the RPM.
Thanks,
Ken
The current drawn seems to be very high......Grounding's good, mechanic thinks that the Fan and AC is draining too much power from the alternator. Car runs perfectly fine without AC, occasionally when cooling fan kicks in, the voltage can drop from 14.1 all the way to 13.1v ...
Thanks,
Ken
Interesting to see how much load (amp) the fan draw when it kicks in. should be easy to test. I bet it consume at least half the alternator output during idle.The current drawn seems to be very high......![]()
Bigger drive to smaller pulley will be heavier, moreover even though won't over charge, will it over work the alternator at high speed?Yeah man, we have a hard time to try to rectify the issue, the original electric fan eats up lots of current. The issue is not apparent if i was driving but at idling. Our next option is to modify the alternator pulley so that at 800 rpm, the alternator can spin faster to increase voltage output, i have a voltage regulator that regulates voltage at 14.5 to previous overcharged.
Thanks,
Ken
10% is a lot... Personally I would not do that to an alternator. Suggest you try uprating it la.The pulley is only 10% smaller than the current size, according to mechanic, it only will burnout the carbon brush sooner. But since the carbon brush is new so it won't be burning out very soon.
What's your input on that statement?
Thanks,
Ken
I am not an electrical nor electronic expert but my previous Accord had the diodes melted in my stock alternator, so not only the carbon brush but will it affect other parts?The pulley is only 10% smaller than the current size, according to mechanic, it only will burnout the carbon brush sooner. But since the carbon brush is new so it won't be burning out very soon.
Thanks,
Ken
Means bigger output alternator rather then over clock the old one......lol10% is a lot... Personally I would not do that to an alternator. Suggest you try uprating it la.
Thanks,
Ken
In that case go ahead and test first......I suggested that, but the mechanic said its not necessary can cure the low rev voltage low problem, especially when fan is kicking in. He asked me to try the pulley first, if it works, then pay, if its not, then no charges.
Thanks,
Ken
Thanks,
Ken
When does it drop to 12v? Does your actual engine RPM drops when it drops to 12v?
:sleep:
