Which Router is the best in the market now?
Dlink.. so far so gd i use, stable connection : ).
1st i use the WRT54G but after 5 hour of using it the adapter blow up...
then i use WRT54GC its find until now...
cheers
Should mentioned which type of router are you referring to lar.....very subjective to answer as you didn't mentioned whether are you interested in wireless router or not...summore didn't state if your usage and expectation? there is tons of different router available in the market to suite your needs but first you have to tell what are your needs before we can suggest mah.....
my 3com wireless disconnect often, need to unplug the power
same to Aztech 4-port router but what u've to do is just update to the latest version of firmware.. so far, no more disconnect thinggy & stable connection..
I've used gigabyte, d-link and level1. All wireless router. So far the best for me is the gigabyte, but it burned already and they are not selling it anymore i guess. the other 2 disconnect often.
aztech admin page is very hard to navigate. 3com config tool is much easier to use
acbc said:
WRT54G... I'm using WRT54GS (ordered from US). Damn good router... plenty of hacked firmwares around to add more features like hotspot, QoS, firewall, bandwidth management and etc...
do they sell wrt54gs in msia? i want that coz i heard wrt54g is not very good for 802.11b
Since i'm in the computer industry, i would say D-link routers work quite well. So is linksys. But the old linksys router, where you need to use the CD to setup the dialler is such a mess to set up. I'm using DI524 with 600T modem. Last time i used a 604T and i sold it off. I think the guy is still using it. Zyxel modems are ok too. I never tried their routers. But i have installed a few Prestige 600 series without much problems.
Try to stay away from some of the lesser brands, is all i can say. There are just too many bad things to stumble into.
my first belkin wireless g-Router paring with D-link DSL 500T modem sucks.....keep on disconnecting every 8 hours (very bad for my p**n torrent download)....but now im using a newer belkin 2.4Ghz router paring with the same modem and its stable and okay.....and the range is not that bad also......i still can surf insides my moms toilet which is around 40 feets away....
i;m using Dlink Wireless 108G Router..stable n fast dowload too
Product Features:
• Up to 108Mbps*• Advanced Firewall & Parental Control• Easy Installation• 802.11g, 802.11b Compatible• Increased Security with 802.1X and WPA
My DLink wireless router sucks ... always disconnecting
Hit by lightning and now using Belkin 2.4G ... stable all the way ...
I have to say I voter for Belkin.
heard someone says Cisco??? Have the money why not??? ekekekeke
Reliability depends on the price itself :)
